If you really care about the welfare of your food and what you're putting into your body, you wouldn't be buying this stuff. Ideally you should be looking at chicken produced to higher welfare standards (Freedom Food, Soil Association Organic, etc) and even looking at buying Organic wherever possible.
Westin Gourmet supply cheap, intensively farmed, mass produced chicken which is about as low-quality as you can get when it comes to poultry. And while they go to great lengths to make it appear their chicken is of a high-quality, the reality is somewhat different:
Westin Gourmet said:
Reared on farms where animal welfare standards are met
Given these are
standards, I'd hope they were met - I'd suggest it would be nigh-on impossible to find a supplier who sold produce from a farm that wasn't adhering to the
guidelines.
100% Class A Chicken Breast
This is just a grading on
visual appearance and has very little (if anything) to do with quality or even taste.
Essentially meaningless when you consider that DEFRA are the farming regulatory body - find me a farm which isn't DEFRA certified in one way or another.
proud to have numerous Red Tractor accredited goodies available to purchase from Westin Gourmet.
The Red Tractor mark is a marketing trick - its 'standards' are some of the lowest when it comes to animal welfare and in most cases barely improve upon the minimum legislative requirements.
