- 25 Nov 2011
- The KOP
CPU spikes could be either BF4 issue or CPU bottleneck. Take your pick.
For page file ive just left it on system managed. Will check to see what usage is like in game later as ive added it to the ab osd.
Has BF4 really gone that bad? It was running okay last time I played a couple months back.
I thought the new drivers for nVidia were not very good for me with BF4. I wasn't fussed, so didn't bother changing them but decided I would roll back to the last drivers that I knew were fantastic for BF4 and blow me, it was doing the same thing. I put the new drivers back on, fired up BF3 and no issues at all.
No idea what Dice are doing but the CPU spikes are pretty bad and everyone I was in TS with was getting them.
Your card is not exceeding the vram limit so don't worry. Did you try that User.Cfg file i suggested? Also have you been reading all our posts, this is a game issue and is nothing to do with your cards.
I did yes, Nothing changed with it.
Yea, Sounds like its just the games fault. I never knew theif was mantle too. Does it run smoothly?
