So this is where you live ?
If you mean Essex, yep.
My olds are from Yorkshire![]()
 great card!!
i dont have interwebs on my test bench.Still need the link Jumper please![]()
i'm not sure i understand? i just enabled sli and ran the benchmark? do i need to change something?Jumper, you must have physic running on the GPUs, 54kCPU score with a 2550k just isn't possible![]()
ive set the cpu to do physicX in nvidia control panel. ill do another run nowCheck your Nvidia settings, not sure how it's done but i know you can force the GPU to run 3DVantage physics and give a false score, as 25% of the final score for Vantage is the CPU
For reference a 5.1Ghz 4 core SB should be getting around 27k.
i got 15193 on the gpu and 25621 on the cpu. 16,914 overall, but my gpu's are slightly lower clocked. i'll have a proper run tomorrow, might have to up the cpu a bit more to bring my score back up to scratch
Your score with those clocks should be 17k (17400 is my guess) at a guess, still not bad![]()
. its weird how it does the physics with the gpu when its on auto in the control panel. thanks for lettting us know or i would never have known!
[email protected]
2x Gtx Titan 1000/6508
3DMark Score
61469.4
Graphics Score
68407.8
CPU Score
47129.1
http://www.3dmark.com/3dmv/5023933
no one cares about my score
I know it is not great but but but![]()
Its a good score bud!!
Gregster is back off his hols anytime now so it will get added then![]()
