this is the system.
Overall I am happy with it, but I obviously didn't get the same sense of achievement from the system that I have done in the past building my own.
A few issues though: -
1) The green LED's are not being sold by OCuk anymore so I had to change the memory
2) The new G1 Sniper Z97 is out - so make sure you go for that mobo and change the LED's to red to match the new Sniper colour scheme.
3) The secondary HDD was not connected properly.
4) I went for SLI 780 ti Gigabyte Windforce OC, but since receiving the build I have heard some horror stories involving gpu artifacts at stock settings whilst using 3dmark11 and Batman Arkham games (not tried either of those to find out yet). Also the cards are loud! They are not loud at stock fan speeds, but then playing games are useless at stock fan speeds! And don't believe the 450 watt fan rubbish. The card runs hot and I have to use a custom fan setting to make the most out of the cards. So to sum them up I would say very loud and noisy. I would go for other brands if I were you! For example my 670 SLI setup never goes near the threshold so never downclocks at stock, whereas my 780 ti's get to the threshold instantly.
5) Had some memory issues in Win8 which seem to have been fixed
6) secure boot isn't working on my system
8) No disc drive in the options, so buy your own.
9) 4770k is overclocked to 4.4GHz, but I checked the voltage and they have set it to 1.34, so the chip I have seems not to be a good overclocker.
10) That damn D4 debug code keeps rearing it's ugly head!
The good points: -
1) The case. Wow that case is the best case I have owned. Get the Corsair 540 Cube case... brilliant.
2) The CPU air heatsinks are very effective and they also cool the RAM
3) Once using Precision X to sort out the horrible fans on the GPU's, the system does fly - although I would prefer to have broken 17k Firestrike on my first attempt! (I'm really picky and my eyes pick up fps dips very easily. I'm and editor and director - so visuals are important to me as are constant frame rates).
4) Did I mention the case? WOW.
5) The 1TB SSD flies. I haven't timed the boot, but from pressing the power button to the win8 login screen it must have been under 20 seconds. Very fast boot times.
Overall I would say a 4/5, but I don't want to write a review on OCuk until I have fully tested the machine over a few weeks. I hope this helps!
