- 1 Dec 2013
not a fan of the layout
What do you mean by "fresh" have you done a decent virus scan. This isn't caused by win8
^ and options exists to modify the layout whilst keeping all those important benefits mentioned by Elevon.
If you have an SSD these benefits are negligible.
You can say that about a lot of Operating Systems,regardless it does not take away the benefits of Win8/8.1 .
Well it really does - unless you have a mechanical HDD it's perfectly valid to say "What benefits?".
Nothing stubborn about it - I'm asking you to give me a tangiable benefit for the average user (i.e one without a touchscreen).
I was under the impression that W8 wasn't improving battery life either?
http://blog.laptopmag.com/tested-windows-7-beats-windows-8-in-battery-life-file-copy-more
And stop rolling out "improved security" as a benefit - that's utter rubbish as W7 is still being supported.
Security is always going to be a concern for both the home and corporate user, even more so when you consider many users work from home PCs and other personal devices. As an IT admin looking to ensure the greatest level of security, you should give serious consideration to adopting Windows 8.1 instead of Windows 7.
3 - Performance
Microsoft revamped the engine under the hood of Windows 8. The result is a faster system which consumes fewer resources than Windows 7, making it a good choice for low-end PCs.
The new OS redesign uses simple colors and fewer visual effects, drawing fewer resources than Windows 7’s Aero Glass effect.
Windows 8.1 performs better than 7 in everyday use and benchmarks. Extensive testing has revealed improvements in tests like PCMark Vantage and Sunspider but the differences are minimal.
Winner - Windows 8 - It’s faster and less resource intensive.
5 - Security
Keeping a PC secure is vital for individuals and businesses. As the most popular desktop operating system, Windows is the primary target for malware and viruses.
Windows 7 and 8.1 share security features. Both use BitLocker Drive encryption, but 8.1 enables it automatically. You can download Microsoft Security Essentials free for Windows 7, but its younger brother has it built into the system.
8.1 also includes support for secure booting on UEFI systems, making it harder for rogue malware to infect the bootloader. PCs running 8.1 can also automatically connect to VPNs.
Winner - Windows 8 - It’s got more security features set as default.
Read more: http://www.itpro.co.uk/desktop-soft...windows-7-which-is-best-for-you#ixzz31ztTmzAw
8 - Data transfers done right
Windows 7 handled copying or moving data the wrong way. When it encountered a name collision between two files, it interrupted the transfer with a prompt asking the user what to do. It would also stack individual windows for each transfer.
Windows 8 cleans that up. It puts all the transfers in one window and pushes name collision dialogues until the end. The Windows guys even tried to make transfer time estimations more accurate.
Winner - Windows 8 - Not only does it transfer data faster but Windows 8 ensure less interruptions - and the time estimates are more accurate.
Read more: http://www.itpro.co.uk/desktop-soft...-which-is-best-for-you/page/0/1#ixzz31zsnQDru
1. Again its all relative is Vista or Win8 a bad OS? ..No ,FUD is always around and what users perceive means nothing,half of them don't have a clue and follow the masses,some have never used the OS in question,a lot can't even install a simple driver.
2. Compatibility is always an issue even on Win7,some still use XP because their software won't work on Win7,but that does not mean its a bad OS.
3. Last point just remember Win7 is based on Vista with improvements,its easy to improve on any OS given time with drivers available(7 had this advantage over Vista since it could also use Vista drivers,Vista had to rely on companies to get drivers out the door) and Win7 also had newer faster hardware available.
It is quicker to navigate and it is quicker in general.
Numbers added for easier reading of answers:
1. Vista brought on a lot of changes, which alienated a lot of users, because it broke a lot of things. Just remember, Windows is an Operating System so it should Operate the system, not cause things to break and this is what most people who aren't techies believe, hence the slow take up of new versions of Windows. Windows 7 (and 8) still uses Vista's Kernel (Version 6), therefore that's why most programs still work on all three.
2. No, but see above.
3. Windows Vista runs slower on older hardware than Windows 7 does on the same hardware. Windows 7 is a refined Vista, (and as mentioned in many places !"It's what Vista should have been") and those refinements are enough to remove the alienation to some degree.
Usually Microsoft screw things up when they do a major update to the Windows Kernel as this changes the way Windows operates, breaking a large amount of programs written during the era of the older Kernel. In Windows 8's case they did it by changing the way People interact with their machines, which unfortunately has not worked out for them as well as they hoped. Improvements made by Windows 8 are now largely overlooked and irrelevant to most people, due to the lack of popularity of the Start Screen.
There is more to security then just updates.
I could also argue Linux has some great security over Win7 or any Windows,but then I think we all know that.
Plenty more in the link.
I do expect GUI/layout changes again and again in the future, too bad others get stuck in the past and want things to stay the same forever.
