WTC7 was from memory hit by a large chunk of debris (hundred ton+), which damaged it.
It was also from memory built around an existing structure (church or something?) so it was weaker when damaged in certain ways than other structures of a similar size would have been.
It then caught fire, and was basically left to burn because the fire service had lost so many people already they didn't want to/couldn't risk losing more for a low value building where people's lives were not in danger.
When you realise those three things it suddenly becomes a lot clearer.
In fact the last item alone would likely result in most buildings collapsing, as any uncontrolled/contested fire in a building can result in it collapsing (as can be seen in everything from house fires, to warehouse fires, to office buildings and shopping malls).
Godzilla did it.
The one argument I see thrown up time and time again in the WTC debate with a CT nut is the "steel doesn't melt at the temperature jet fuel burns" fallacy.
No, it might not, but heat invariably will reduce it's structural strength, and thermal contraction and expansion can be a big factor in engineering. A steel structure doesn't have to reach it's melting point to fail.
Also all explanations work from the assumption the building is to code, just like it says on your mot "at time of test", over the years do you really think every bit of maintenance, every firewall bung and cable block and conduit, every in ch of the brittle temperature resistant coating on the steel is in place? that no builder doing a job inside a crawl space didn't drop his hammer and chip some off and decide it wasn't worth the hassle of reporting it and getting in trouble if he even noticed?
that none of it was knocked off by the force and vibrations that would have spread through the steel structure from the massive impact let alone any caused by the towers and other debris falling.
little things can add up a lot small weak points when heated extensively unprotected suddenly become failure points, lots of them combined can have an effect thats incalculable.
Also the calculations done in the analysis are a lot of guesswork because of how utterly absurdly complicated the level of detail required is.
I don't think he is saying NOTHING hit the towers, just that they were not pilot controlled 767's.
+1
OP, what you put in the title was not what he said.
Ah I see you got it from the title of the article, I absolutely hate article titles, they're always false and misleading.
The vertical and horizontal tail would have instantaneously separated from the aircraft, hit the steel box columns and fallen to the ground.
‘The engines when impacting the steel columns would havemaintained their general shape and either fallen to the ground or been recovered in the debris of the collapsed building.
How did you two come to that conclusion
Wait..
So the video feeds (to the world) were actually CGI ?
I believe it was a black flag op but to say those planes didn't actually crash into them ?
I feel sorry for The C.I.A in all this Tin Foil Hat nonsense.
They pull off one of the greatest victories on American soil and white idiots want to take the blame away from them.
