New Rig - - £1,000 budget.
4 Apr 2014
I'm putting together a new gaming PC and would like someone to validate the below looks ok or make some suggestions.
I'm a bit new to overclocking and have relied on the software OC option to get the most out of the CPUs I've had. I've also just heard that there is a new release of Haswell and Z97... would it be worth considering that if I need to purchase in the next few weeks?
I also need to get a case so any advice on that?
Processor: Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor
Cooler: Noctua NH-D14 Dual Radiator CPU Cooler
MotherBoard: Asus Z87 SABERTOOTH Intel Z87 (Socket 1150) DDR3 ATX Motherboard
RAM: TeamGroup Vulcan ORANGE 16GB (2x8GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit
HD: Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM HDD
SSD: Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic
Hard DiskSeagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache
Graphics Card: Gigabyte GeForce GTX 770 WindForce 3x OC 2048MB GDDR5 PCI-Express Graphics Card
Wireless Card: Asus USB-N13 300Mbps Wireless Adapter
Power Supply : Corsair RM Series RM 850 '80+ Gold' 850W Power Supply (CP-9020056-UK)
Thanks for any help.
Hi jilazee,
Do you want 2 x Barracuda 2TB, or is one of them an error?
Assuming one's an error, this is how your basket looks:
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £251.99
1 x Gigabyte GeForce GTX 770 WindForce 3x OC 2048MB GDDR5 PCI-Express Graphics Card (GV-N770OC-2GD) £239.99
1 x Asus Z87 SABERTOOTH Intel Z87 (Socket 1150) DDR3 ATX Motherboard £176.99
1 x Corsair RM Series RM 850 '80+ Gold' 850W Power Supply (CP-9020056-UK) £119.99
1 x TeamGroup Vulcan ORANGE 16GB (2x8GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLAD316G2133HC11ADC01) £119.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £67.99
1 x Noctua NH-D14 Dual Radiator CPU Cooler £65.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £59.99
1 x Asus USB-N13 300Mbps Wireless Adapter £19.99
Total : £1,132.50 (includes shipping : £8.00).
You're over budget and don't have a case yet. Do you want help bringing the build down to £1000 or set budget at say £1200 including case?
Also, do you need Windows and optical drive at all?
Hi
If you are not purchasing for a few weeks then I would definitely wait for the upcoming unlocked cpu's. They should run a lot cooler than the current ones.
I think they are due around the middle part of June.
A couple of questions on your requirements:
Do you need a copy of windows ?
Are you planning on building this yourself ? Or are you looking for pre-built ?
Are you looking at running dual graphics cards in the future ? Or just the one ?
Are you set on Nvidia for the graphics card ? Or will you consider an AMD card ?
As for a case, the Bitfenix Ronin is a good mid range one. If you want something a bit roomier then the Corsair 540 is also a good choice.
Thanks for the quick replies you guys are great.
Over budget is fine, I'll be getting the VAT back, so ~£1100-1200 is fine.
Also, do you need Windows and optical drive at all? - No to windows yes to the OD.
2 x 2TB disk. That is an error with the two disks. I have a Synologoy NAS I use as an external backup so a single disk is fine.
Do you need a copy of windows?
I have a copy of Windows 7 Pro. I'll get around to sorting out a Win8 at some point in the future.
I can build it myself so shouldn't be a problem.
Might look to run dual in the future. I currently have a 660TI and an old 480GTX I think. I run my main monitor on the 660 and the 2nd on the 480.
I've always purchased Nvidia but if the benchmarks are worth it bang for buck wise I'd consider AMD.
Case wise I quite like the look of "Cooler Master Cosmos SE Mid Tower Case"
I think what lee meant by two GPU's was in SLI/Xfire, so two GTX 780's in SLI. This will improve frame rates on games, on one or more screens. :)
As for the case, that Cosmos is a poor choice, very little cooling and NO watercooling support, and really expensive for what it is. :)
If I had £1200 for a gaming rig, i'd do this:
YOUR BASKET
1 x Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card £319.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £239.99
1 x Gigabyte Z97X-Gaming 5 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £109.99
1 x Seasonic M12II EVO Edition 850W '80 Plus Bronze' Fully Modular Power Supply £89.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £88.00
1 x BitFenix Ronin Tower Case - Black £69.95
1 x Corsair Vengeance Pro Red 8GB (2x4GB) DDR3 PC3-17100C9 2133MHz Dual Channel Memory Kit (CMY8GX3M2B2133C9R) £59.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x Corsair SP120 Performance Series High Pressure - Dual Pack (CO-9050008-WW) £22.00
1 x Corsair AF120 Performance Series Low Noise High Airflow - Dual Pack (CO-9050004-WW) £22.00
1 x Samsung SE-S208DB/TSBS External Slimline 8x DVD-RW (TV Connect) - Black £21.98
1 x BitFenix Alchemy 24pin ATX extension 30cm - Red £8.99
2 x BitFenix Alchemy 6+2-Pin PCIe Extension 45cm - sleeved red/black £5.99 (£11.98)
1 x BitFenix Alchemy 8pin EPS extension 45cm - Red £5.99
Total : £1,225.72 (includes shipping : £19.10).
Yes I was referring to CF/SLI :)
Doomed has it spot on with that spec.
If you are not in a huge rush though, wait for the unlocked refresh cpu's.
