Nvidia GTX Titan @ 1346/1925, 4770K @ 5.0Ghz
E: 1080P
Gregs on Sandy bridge E, not Ivy and at lower clocks on both Core & Memory with his Titan.
Kaap on a 4.8Ghz Haswell only got 61.3 FPS.
Greg on a 5Ghz Ivy got 60.5
On a 5Ghz Haswell you got 65..6
It doesn't explain how he's 8% faster than Kaap on the cores.
And 13% Avr than Greg on the GPU and 18% faster on the Max FPS. those are huge differences.
Would love to oblige - alas my PSU on that rig is DEAD![]()
Something seems amiss there. Perhaps scotty can run with one of his titans to compare. If i trust anyone, its that man from Wigan.![]()
To compare he would need to be able to run both his 4770k at 5GHz and his Titan at the same clocks.
To be honest the last thief bench thread had some really weird results mainly on the NV side.
I found these results looked off for obvious reason's.
1. MjFrosty-780ti@1315/1965, [email protected]
2. khemist-780Ti@1410/1905, [email protected]
3. gregster-Titan@1267/3767, [email protected]
5. whyscotty-Titan@1241/1802, [email protected]
Note how the 6 core cpu's seem to do better as well even if they are slower core per core.
I'm sure even similar clocks would be fine. Typically a slight gpu clock speed difference does not equal a massive fps difference, especially on single cards.
This game seems to favour 6 cores, but will need a bigger sample size i guess.
