- 15 Feb 2013
- Edinburgh
It's looking great
I feel like the GPU back plates should be candy white ngl. great build otherwise.![]()
I'm of a similar kinda feeling - the solid black of the GPU's and the bridge could be broken up some, an easier solution would be some white EK-plugs on the bridge? Totally down to your preference though - painting the backplates would probably work out cheaper!![]()
Get an evga bridge and spray it white!
Mine turned out well![]()
Nice build mate just bought the same case in white also so sexy
Got a question for you the rad under the videocards,can you fit 120mms there instead of the 140mm?
Yes, the radiator at the bottom is 240mm one, so can fit x2 120mm on the bracket that is supplied at the bottom of the case.
On another note, i've been talking to Monsoon and they are trying to sort me out a custom white faceplate for the front of my bay res!
Check out my build log whiteknight it's in there
The tidyness of the rear is amazing! How did you get it so clean and perfect looking? My cables never seem to be the right length and always seem to be cramped in a couple of key areas...
On another note i was thinking of changing the GPU's from series to parallel circuit, will this make the temperatures between the cards equal? I don't know much of the difference, other than the looks ofcourse?
I honestly might have to copy this build but not sure if the red on my mobo would **** it up..
Well there is red lights on my RIVE Black Edition motherboard, to be fair white black and red goes well together!![]()
Guess you wouldn't notice it after tubing/blocks done. Why didn't you go with Acrylic?Mate this looks great. Really nice job on the build.
