I'm about to scream!!!!!!!!!!
I might not have any choice but get 4770k. It's either buy now or not at all. Can't wait until September. So 4770k work with z97 mobo's
I buy based on what's best value VS performance at the time...
or flat out best performance. Atm the it's Intel..
..and a 4770k/4790k with corresponding motherboard plus 1-2 290x card is not it I'm afraid. If you think that combination is best value vs performance, you are mad.
Yes, although GPU-wise, I'd argue it is Nvidia rather than AMD, but that's a different story. In pure raw GPU-power, it isn't a Haswell CPU-based system either, it is what can drive the most GPUs, which at present is a well clocked SB-E or Ivy-E Hexcore for high end tri and quad SLI setups.
Yes 4770k does work on z97 motherboards
Yeah 4770K works mate. Not long till we get some legit info on the launch date. You could just pick up a used 4770K until 4790K appears?
Putting my Z97 together atm. Impressed with the mobo and case for the money, The heatsinks aren't yellow like in pics, more like muted gold..
4770K + Gigabyte GA-Z97X-UD5H
Let's hope nothing DOA![]()
Thanks
I guess I could get a 4770k & z97 mobo now then pick up a 4790k in September? At least I wouldn't need to buy a new mobo then. The thing is I have the money now and might not then. Last year money was tight in september....That's why I bought stuff in the summer.
Worth waiting a couple weeks and see if anything does happen around June 2nd..
Go for a decent priced used 4770K and it's not so bad then.
you get your board then boom? whats it like ? audio ect
think theres no way of adjusting vring voltage atm or correct software monitoring,but its being looked into
as per my other thread i need a new mobo for x58 or z97 + cpu
more i gather whats going on more i get irritated
to the point where i am considering a new x58 board - but they are hard to find!
basically i need to shell out for something!
at present im 50:50
tempted to get a cheap cpu compatile with z97
it might be current software monitoring isn't accurate atm,i remember someone mentioning it but no big deal
EDIT: the sapphire card is perfect colour match for that board,goes well
Yeah, built today bud. Project log is here - http://forums.overclockers.co.uk/showthread.php?p=26336174#post26336174
The board is really good for the money. Audio is great, overclocking is easy. vring is adjustable, got to 4.4Ghz on 1.28v core and 1.15 vring no problem, needed 1.3v core for 4.5Ghz booted into Windows but unstable. Don't wanna push past that voltage tbh. Need time to get used to the mobo.
