Which would you go for?
5 Oct 2012
Hi all,
I am looking at getting a new GPU but ive been out of the loop on components for some time now, so im asking peoples opinions on which card you would buy with your own money and reason why over the others
Here is the shortlist:
R9 280
http://www.overclockers.co.uk/showproduct.php?prodid=GX-251-MS&groupid=701&catid=56&subcat=1842
R9 270X OC
http://www.overclockers.co.uk/showproduct.php?prodid=GX-242-MS
760 OC
http://www.overclockers.co.uk/showproduct.php?prodid=GX-206-MS&groupid=701&catid=1914&subcat=1830
For a little more info, im also lookin at 2 of these screens
http://www.overclockers.co.uk/showproduct.php?prodid=MO-028-AS
Right, fire away :)
OP
5 Oct 2012
Billysielu - I wouldnt really want to go much higher,unless the gain were exponentionally greater.
I'm getting married in July so cant justify too much of a cost at the moment.
LtMatt - i had a look at the powercolor stuff but was put off by a fair number of bad reviews on a number of different websites.
Caporegime
12 Jul 2007
United Kingdom
Powercolor have a good relationship with ocuk, so the RMA process is a quick turnaround. I'd ignore those reviews to be honest. Nothing wrong with the 280X from Powercolor at all.
Caporegime
8 Nov 2008
Best bang for buck :
http://www.overclockers.co.uk/showproduct.php?prodid=GX-162-PC&groupid=701&catid=56&subcat=1982
http://www.overclockers.co.uk/showproduct.php?prodid=GX-328-SP&groupid=701&catid=56&subcat=1982
Top end of budget :
http://www.overclockers.co.uk/showproduct.php?prodid=GX-171-PC&groupid=701&catid=56&subcat=1842
Should you wish to select an Nvidia card :
http://www.overclockers.co.uk/showproduct.php?prodid=GX-118-GI&groupid=701&catid=1914&subcat=1830
You haven't specified a maximum budget, so I have tried to keep prices no higher than the examples you linked to. There won't be much performance difference at stock speeds between the 270X & 280, though the 280 will push ahead nicely once overclocked.
To give you an idea of the minimum performance boost you would receive by going from a 6950 to a 270X, here is a rough guide (I've used a 7950 to represent the 270X) :
http://www.anandtech.com/bench/product/510?vs=550
OP
5 Oct 2012
So that is 2 expeirenced members who have suggested a Power color....
It was actually the power bank one i was looking at when i started to find bad reviews.
your assumption was bang on, i cant really go any higher than the cards i had referenced.
Im not really looking to OC, as its not something ive evered bothered with before so maybe the cheaper one (270x) might be a better option? Although the price difference is nothing atm.....
