Crossfire two graphics cards - newbie help !
6 Jan 2014
Hi guys,
I'm thinking of crossfiring 2 AMD R9 290's I have. I was wondering apart from the actual graphics cards are there any other hardware items I'm gonna need.
My motherboard is Gigabyte G1 Sinper Z87 which I think is capable of crossfire and I have 8Gb of Ram.
RJC
RJC
Don
29 May 2005
Kent
Nope, install the 2nd card and crossfire bridge and hopefully the CCC will see the 2nd card load the drivers and enable crossfire.
18 Oct 2011
You do not need the xfire bridge any more it is all done over the PCIE Slot.
Your good to go providing you have a good quality psu, preferably 800w or above. No bridge needed with 200 series cards.
750w Gold/Plat would be fine.
Caporegime
14 Dec 2005
armoy, n. ireland
Yep, does look kinda weird when you see it and no bridge there. 750w gold/platinum should be ok as long as your not pushing heavy overclocks with increased voltages on the cards.
18 Oct 2011
@RJC
Sorry to go extremely off topic here but seeing as you are a Forum Staff Member is there anyway for you to contact the admins? I sent two emails a week and a half ago with no reply. (was regarding a name change)
RJC
RJC
Don
29 May 2005
Kent
@RJC
No probs, I will put a note in with a link to your post :)
Edit: done, but it might take a day or two :)
OP
6 Jan 2014
for psu I've got a silverstone 1200w gold - possibly overkill :)
So just to confirm I just stick in the second card with no bridge right ?
Also I have 8GB of ram is this good enough or is ram not a factor ?
27 Jun 2006
Not here
I have an OCZ 780W PSU with an 290 and when I tried crossfiring with another 290 the computer rebooted when I tried the Firestrike Benchmark due to lack of power. (Error came directly from POST) So I suggest an 800w minimum.
Also nothing in my computer is overclocked.
OP
6 Jan 2014
I got a 1200w gold silverstone although I would think a 780w should work with dual 290 but i guess it depends on power usage of the other parts too.
Not planning on doing any overclocking either m8 !
OP
6 Jan 2014
also guys, what about the monitor. I have a 24inch dell ips and am currently using the display port connection with the 290 on the PCI-e 16 slot. Will this all stay the same or will I have to mess around with the second card's video output ?
