Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
I've never needed the level, if pushed, there is one built in but normally judge by eye.
And a mic.
[/QUOTE]
What mic is that?
Wrong thread.
Any recommendations for a good first turntable?
Got a pedal basically on a whim, sending it back tomorrow for a refund, think i'll get something else.
Nope, mine is plugged directly into the phono port on my arcam alpha 5.
I was looking at the tube box s as it's cheaper than the ds. Wonder if it would be better than the arcam?
That looks great, where'd you get it from?
Thanks! John Lewis. £55![]()
Thought the hoodie was a bit expensive for the quality but was overall pleased with all the tshirts prints and thought it was good value. But wouldn't buy another hoodie from there as its one of the single layer american hoodies.
Technically this only half count.
Nice pedal but you can't go wrong with with the Behringer RV600 (no, seriously!) or Boss RV5. Plenty of other boutique pedals out there that are great but I've tried loads and these two are about the best bang for buck. 'Shimmer' effect on the RV600 is lovely, add in a POG and you're talking proper shoegaze!
Keeley and JHS are some good boutique pedal manufacturers/modders that are worthwhile investigating.
Andertons Guildford? Bunch of dicks.
If you're looking for an overdrive, get a modded Boss DS-1
