Only if you run it at the ridiculously low stock clocks...
It has higher OCing headroom than any of the other current high end cards. Proof should be pretty blatantly obvious.
Personally I don't particularly care about stock. I run mine at ~1350MHz for gaming which is around 370MHz over stock. Let's see gaming clocks like that on the R9s...
You don't give up do you?
I can do a 300Mhz overclock on mine with its stock cooler and the original unmolested BIOS, its nothing special, stick a watter cooler on it and unlock MSI AB Benching volts i have no doubt it will do a lot more, but what the hell for to risk blowing it, willy wagging?
In anycase Stock clocks are already way higher on the Titan than the 290/X because of GPU Boost 2, they already run at 1100Mhz out of the box, some even higher on short runs.
So while a 25% over clock on the 290X is 1250Mhz, the same 25% overclock on the Titan is more like 1400Mhz + in terms of getting it to run higher than it otherwise does.
Nor will the Titan get there without modifying it as its locked to minimal volts and power envelopes while the 290X is not lock at all, not to mention half the price and yes faster in the real world.
You paid $1000 for a card that is no faster than my $380 290.
Its not a competition. at least not to me, its a bit of fun. i don't care about your Titan and its ~7K Score, good for you, i don't care much for the justification of $1000 and Water cooling, modified BIOS and running it to the brink of destruction to beat me, good luck to you, i don't buy it. i'm not an idiot. i have no need to justify the price of my GPU, i wasn't the one ripped off.
I'm out/:
