Hi,
It's great to see Overclockers supply decent headphones. I understand that you want to keep the number pretty small at the start, but, don't limit your range too much as there are a lot of people who like open and other people who like closed and there are some decent semi open phones out there are well. I would try to supply 3 or 4 of each type.
Here are some models that I think would sell really well.
Superlux 668B,
JVC HA RX900,
JVC HA RX700,
Beyerdynamic DT990 pro,
Beyerdynamic DT 770,
Sennheiser HD 558,
Creative Aurvana live (both versions, 1 and 2)
Audio Technica AD700,
Philips Fidelio X1
There are other great phones out there, but I think these models would cover most of the bases.
Momentum is a waste of time. It's just a more 'stylish' HD25-1 II with metal covers (some claims this affects the timbre of the headphone, but thats absolute crap) with a higher price tag.
HD25-1 II isn't ideal for gaming either, it's a portable headphone through and through and doesn't have the widest of soundstages.
With regards to DT770 vs DT990 for gaming, the latter will be better as it is open, allowing for a greater soundstage and to a lesser extent greater clarity - key factors in gaming headphones.
HD 558 aren't that good and the AD700 is EOL
The 558 are a really good headphone for the price. As good as the 598 after you take out the black tape stuck to the inside of the cup, A very simple mod. The 598 and the 558 use nearly identical housing and identical drivers, right down to the same part numbers.
Yes, the AD700 is EOL but they still can be got and if they can't get them, The new model is called the AD700x. I am pretty sure the staff here would work it out.
Load of rubbish about you can turn a 558 into a 598.
You could do it with a 555 to mod into a 595.
But with the 558 some parts are completely different, the mod makes it sound better but still nowhere near a 598. Head fi backs this up.
here's the mod and according to the reviewer it makes the 558 sound even better than the 598
http://www.headfonia.com/sennheisers-new-hd558-and-hd598/3/
from a business sense however.
