CompuBench 1.5 Bench thread
Caporegime
OP
12 Jul 2007
United Kingdom
Any idea why in the "face detection" part of the benchmark my score is a bit low?
Don't know. Have you tried running it again to check? Could be your memory is not fully stable in that test and there was some error correction? Experiment and retest using different clocks. Could also be the fact you're on 14.4 drivers and we're all using 14.6.
Permabanned
30 Apr 2014
Tried 14.6 beta and it was a slightly worse result. Will try different clocks to see if that makes a difference. Thanks.
Permabanned
30 Apr 2014
Figured out the problem. It seems with powerplay on it affects the score a bit on the first test.
Here's the updated results using 14.4 Whql :-
29 Aug 2010
Cornwall
Particle Simulation
1 GPU.
1. Score 831.053 GPU 290X @1340/1625, Kaapstad Link 14.6 Beta
2. Score 743.491 GPU 290P @1100/1400, win8.1 Link 14.4 WHQL
3. Score 739.009 GPU 290P @947/1250, thefogo Link 14.6 Beta
4. Score 707.672 GPU 290P @1100/1400, Humbug Link 14.6 Beta
5. Score 736.981 GPU 290P @975/1250, LtMatt Link 14.6 Beta
6. Score 551.318 GPU 780 @1215/1700, IanEvey Link 337.88
Seems like LtMatt doesn't do numbers too good :)
I made sure to quote it LtMatt, so you can't change it and make me look silly. I'm a slow learner, but I get there :)
EDIT: You did catch my spelling mistake there though, so it looks like it's 1-1. Touche! :)
Permabanned
30 Apr 2014
I only added the scores which improved over your old scores. Scoreboard updated. :)
Thanks. If you could remove my lower score on the first test as it looks strange having two completely different scores with the same clocks and drivers. :)
Permabanned
30 Apr 2014
I hope the extra heat produced with the 14.6 beta's is not going to be something that carries on into future releases.
If it was 5 to 10fps extra I would not mind the 6c increase but in Crysis 3 they add no noticeable difference in framerate even with the fps counter on.
