I was ordering batches of 6, waiting for them to arive before sending the old ones back, failing that I then moved onto a different manufacturer...
1800 quids worth of cards a time 0_o
2 Titan Blacks? Nice, I'm sure you'll enjoy them
P.S. You don't need to apologise to AMD, it's them who should be apologising to you for designing a sub-par product.
I don't know the circumstances, but 30 cards with excessive coil whine suggests an issue. I'm not going to argue about it though, there's nothing to debate here - don't want to start another 20 page nonsense thread, so I'll leave it at that and wish the OP the best with his new cards.
This is where he runs of the iGPU until his new cards arrive and discovers the whine is from his motherboard![]()
Who cares....
Op! Great cards you've just bought. Enjoy!
Mobo is the only thing which I havent changed as I have tested it with a known coilwhineless card and... no whine
And when I mean 0 whine, I mean ZERO, not low levels that you cant hear over a fan or you cant hear in a closed case.
OP said they have tried 3 different PSUs so I doubt that's the issue, not much else gets noticeably loud coil whine problems apart from GPUs and PSUs but I suppose it's not something that can be ruled out. However, having tested so many cards I hope the OP also tested various other components within their system, would only be logical.
Sure are great cards, but what I care about is what this has to do with Amd. Unless op can confirm there reference cards.
If there GPUs from other manufacturers are they not to blame for the coil whine?
Coil whine is something horrible to figure out and I would hate to be in the position to have my card with it.
But with both amd and nvidia getting it doesn't it tell you something else is at play here psu or something.
30 cards tell a different story am sorry.
