Mantle...
here we go failed log!
<?xml version="1.0"?>
<?xml-stylesheet type="text/xsl" href="Report.xml.xsl"?>
<monetreport xmlns:dt="urn:schemas-microsoft-com:datatypes">
<general>
<cmdline>-UI </cmdline>
<time>06/04/14 15:48:29</time>
<action>install</action>
<download></download>
</general>
<dcm>
<device>
<name></name>
<manufacture>Advanced Micro Devices, Inc.</manufacture>
<chiptype></chiptype>
<chipid>0xaaa0</chipid>
<vendorid>0x1002</vendorid>
<ssid>0xaaa0</ssid>
<ssvid>0x1462</ssvid>
<classcode>0x040300</classcode>
<revisionid>0x00</revisionid>
</device>
<device>
<name></name>
<ssid>0xaaa0</ssid>
</device>
<primary>
<name>AMD Radeon Graphics Processor</name>
<chipid>0x679a</chipid>
<ssid>0x2761</ssid>
<classcode>0x030000</classcode>
</primary>
<device>
<ssid>0x2761</ssid>
</device>
</dcm>
<exist>
</exist>
<install>
<package>
<description>AMD Catalyst Install Manager</description>
<result>Succeed</result>
<version>8.0.916.0</version>
<size>20 </size>
</package>
<package>
<description>Microsoft Visual C++ 2012 Redistributable (x86)</description>
<version>11.0.50727</version>
<size>9 </size>
</package>
<package>
<description>AMD Display Driver</description>
<version>14.100.0.0000</version>
<size>90 </size>
</package>
<package>
<description>HDMI Audio Driver</description>
<result>Fail</result>
<version>9.0.0.9905</version>
<size>1 </size>
</package>
<package>
<description>Microsoft Visual C++ 2012 Redistributable (x64)</description>
<size>9 </size>
</package>
<package>
<description>AMD Accelerated Video Transcoding</description>
<version>13.30.100.40415</version>
<size>3 </size>
</package>
<package>
<description>AMD Catalyst Control Center</description>
<version>2014.0415.2225.38428</version>
<size>150 </size>
</package>
<package>
<description>AMD Gaming Evolved App</description>
<version>1.10.000</version>
<size>49 </size>
</package>
</install>
<uninstall>
</uninstall>
<downloaded>
</downloaded>
<resource>
<hwinfo>Hardware information</hwinfo>
<existpkg>Existing packages</existpkg>
<pkg2inst>Packages for install</pkg2inst>
<pkg2uninst>Packages for uninstall</pkg2uninst>
<otherdev>Other detected devices</otherdev>
<errmsg>Error messages</errmsg>
<name>Name</name>
<manufacture>Manufacturer</manufacture>
<chiptype>Chip type</chiptype>
<chipid>Device ID</chipid>
<otherhw>Other hardware</otherhw>
<download>Download packages</download>
<succeed>Success</succeed>
<fail>Fail</fail>
<vendorid>Vendor ID</vendorid>
<classcode>Class Code</classcode>
<revisionid>Revision ID</revisionid>
<ssid>Subsystem ID</ssid>
<ssvid>Subsystem vendor ID</ssvid>
<header1>Catalyst™ Install Manager</header1>
<header2>Installation Report</header2>
<finalstatus>Final Status:</finalstatus>
<versionofitem>Version of Item:</versionofitem>
<size>Size:</size>
<bytes>Mbytes</bytes>
</resource>
<error><msg>Driver Install:the driver package is already preinstalled</msg></error> <error><msg>Driver Install: the installation failed</msg></error></monetreport>
Looks to me like the sweeper tool you used has borked something if it says the driver package is already installed. Avoid the sweeper tools and you'll never have a problem like this. Using DDU in safe mode without uninstalling the drivers properly first is a sure fire way to get driver install package errors on your next install. I can reproduce it at will.
ok so its borked neither here nor there what i used now, just need to sort it out. Avoiding a full windows installation would be good as i upgraded from 8 to 8.1 and that means it doesnt like my windows key! and i dont want to install 8 then 8.1
Do we really need another Mantle thread.
Yes. We don't have enough Mantle threads. Actually Mantle deserves it's own section imo. :D
You can try repairing your windows installation, but im not sure how that affects your existing files.
I can educate you Mr Chop. Here is what Mantle can offer. :)
i7 3770k 4.6ghz
MSI z77 mpower
Gskill sniper 16gb 1866mhz
Evga 780 ti sli Water Cooled
Intel 240gb
Seagate 2tb
hgst 1tb
seasonic 1050w
AVG FPS: 93.8
MIN FPS: 56.6
2700k@5Ghz
Asus P8Z77 WS
16 GB DDR3 2133Mhz
290P Crossfire Reference cooled
Samsung 250GB SSD
Mantle API
290P @ stock clocks 975/1250
AVG FPS: 101.0
MIN FPS: 121.9
290P overclocked @1250/1625
AVG FPS: 109.5
MIN FPS: 142.5
Lambchop, Mantle would be great for 120HZ users. Just look at those minimum fps. Who doesn't like high minimum and average fps? Everyone loves those and this is what Mantle users can look forward to. Lets not forget these ridiculously consistent frame times Mantle offers which makes DX11 look and feel like a chore in comparison.
Mantle must be really magical if the min FPS is higher than the average:eek:
its odd cause everything installs apart from the sound element. So i cant use 5.1! most annoying which means i cant use XMBC as it stutters because of it.
Should we not offer assistance in that case?
..Or did you simply forget the smiley? ;)
We should definitely offer assistance but in the proper Mantle thread(s).
What the hell is it, and yes ive googled, but im a simpleton.
Do i need it? Can i use it?
How can anyone miss all the Mantle threads in this forum, some of which have shedloads of excellent help and assistance.
Don't have a hernia Kaap, but this isn't even related to Mantle!! :eek: :eek: :D :eek: :eek:
Brilliant and thanks for your helpful input, i'll be sure to make sure i take all the advice and useful information on-board.
True. What started as a 'What's Mantle?" thread is now a "Help me get these drivers installed so I can try Mantle" thread ;)
Either way, not anything to be bothered about eh?
yep :( sure has. Now what to do next... Im downloading a new 8.1 ISO to try and put on a flash drive in order to see if i can repair windows. GOOD OLD WINDOWS!
