- 18 Oct 2002
- Manchester
Started training again end of Dec. I've just finished a 4 month routine of my own to build some basic strength and get my stamina back. Got bodyweight down from 16st 7lbs to 15st for a total loss of 21lb in the first 3 months, then upped the calories a little and I'm currently around 15st 5lbs at 6' 1". Really sorted my diet out to godly levels of goodness and completely knocked booze on the head, have not touched a drop since New Years Eve.
So I've just had a week off to let my old bones heal and I've decided to go for....
Lyle McDonald's Generic Bulking Routine
Workout 1 of 4
Lower A
Day 1
Front Squats [60 sec] = Upped the rest times from 45 sec to 60 sec, see if this allows me to get the weight higher. 100kg is a sticking point for me on this exercise, once I go heavier I struggle with holding the bar in place.
WU = 20xbar, 3x50, 3x70, 3x90, 3x95
3x100 -
3x100 -
3x100 -
3x100 -
3x100 -
3x100 -
3x100 -
3x100 -
RDL [90 sec] = Taking it very easy to try and learn the form again, lots of warmups, more than I would normally do. I haven't done these in a long time!
WU = 12x40, 12x50, 12x60
12x70 -
12x70 -
45 Degree Leg Press [120 sec] = Feet close together to hit the outer quads. Constant tension, no lockout.
WU = 10x100x 8x200
12x300 -
12x300 -
10x300 -
Seated Leg Curls [90 sec] = Got the weight wrong here
13x50 -
12x60 -
12x60 -
Seated calf Raises [75 sec] = Squeeze at top, slow controlled negative
15x50 -
15x50 -
12x55 -
10x55 -
Pallof Press [60 sec] = Pause for 1 at start, power twist, retun slowly, pause for 1, repeat.... these hurt!!!
12x30x2 -
12x30x2 -
12x30x2 -
Total Workout Time = 90 mins
Workouts are taking longer than usual as I now have my 17 year old lad as a training partner who I need to keep a close eye on. He's as tall as me but weighs just 9st, so I'm going to beef him up. Got some of the weights wrong, I'm supposed to be starting with the heaviest weight and pyramid down if required to keep the reps up, or keep the weight and try to hold reps. If I can rep for 12 then the weight needs to be increased, so learning curve here.
Workout 1 of 4
Lower A
Day 1
3x100 -
3x100 -
3x100 -
3x100 -
3x100 -
3x100 -
3x100 -
3x100 -
12x70 -
12x70 -
WU = 10x100x 8x200
12x300 -
12x300 -
10x300 -
13x50 -
12x60 -
12x60 -
15x50 -
15x50 -
12x55 -
10x55 -
12x30x2 -
12x30x2 -
12x30x2 -
