Deleted member 66701
Hey amiga, is that legal in the UK?
No, but if it looks like a bike, sounds like a bike then to 99.9% of people it's a bike. Just don't crash into anyone
If you want legal then something like this plus a 36v battery will keep you at around 16mph assist speed to be legal (you can still pedal faster, but the motor will stop helping you above 16mph), and as you're going slower you'll use less battery - so will probably still be capable of doing 25miles with light pedaling.
The hub motor above is also geared - which means it has a freewheel so it's easy to pedal when not using the electrickery, just in case the battery runs flat whilst you're out
If you fancy converting an MTB that you can also take off road then have a look at a crank drive kit from EM3EV - it'll still max out at around 16mph but it will climb hills like a mountain goat. Crank drives are also freewheeling, so you can pedal with the electrickery switched off with no noticeable drag. I can custom program the Bafang BBS units (change assist levels, 100% throttle in all PAS modes, crank cadence etc) - for a few beer tokens of course
