- 22 Feb 2014
We have a new build house so that means unfortunately we have a truss style roof (more work and more expense)
I would like to find out roughly what cost I would have to convert my loft space to a useable "space", the reason I say space is realistically the rooms on the 1st floor are so small we couldn't afford to lose space out of any of those rooms to make way for a staircase, so I would have to have access to this space via a loft ladder.
I plan on making the room my office which is currently in bedroom 3.
the timbers in the loft are 5 x 2, am I right in thinking I would need to upgrade toi a 7 x 2 to support a floor without causing esxcess stress on ceilings and door frames in the floor below ?
Most loft conversion places want £10k+
As I will never be able to fully and properly convert the room, how much would I be looking at to fit the new floor beams and move the trusses/add new supports for the roof.
The rest of the work I could either do myself or get done later.
for example
I could fit the floor,
I could install insulation in the roof and plasterboard over it.
I could run wire for lighting and sockets then have an electrician connect my wiring to the house and check he is happy with my wiring.
I seem to think I could save quite a bit of money doing it this way and I am not bothered about it ever being classed as a proper room. it will just create office space for me to work in.
for example
