My driving sunnies are Oakley Whiskers with polarized black iridium lenses - no complaints.
There is a picker tool here if it helps
You want a neutral colour tint, I use black iridium splinters for flying and driving. Although I'm getting annoyed at oakley discontinuing all the decent wire models!!
The biggest bit of advice I can give you, and listen well when I say is:
Seems that black iridium is the majority reccomendation. Cheers
Thanks for your "pro" poker tips. I'll ignore everything you said unless you've cashed more than me in the last 12 months![]()
You also want to avoid polarised. You'll have issues looking at the displays in the car as well as with coated glass, can be very annoying!
and the only reason you won so much is obviously the sunglasses you wear!
i may not have cashed mega bucks, but hell, at least i can hold my head high and say i've not looked like a complete tool.
I'm getting confused so go gentle.
The OP wants Oakleys but he's going to have his eyes tested before committing.
Do you then send you prescription to Oakley who then 'Oaklify' the lenses?
This is pretty much the complete opposite of what ive been told everywhere else.
Serious question, why don't you opt for wearing contact lenses then you can wear whatever sunglasses you want? Probably far cheaper. My contacts + solution + checkups probably cost me <£150 each year. Prior to this I used to use prescription sunglasses for driving.
Sounds like they weren't fitted properly. If they're measured correctly then they shouldn't move.
You send your prescrption to Oakley, who then make the lenses as per your prescription and customisation options.
Didnt realise they came in differeing sizes?
Maybe ill give it a go, though horrible eye pain is...not fun so you can imagine im not too enthusiastic about that prospect again.
http://www.eyehealthweb.com/uncomfortable-contact-lenses/Fit: This is the most common reason for discomfort among lens wearers. If the diameter of the lens and the base curve are incorrect in size, whether it’s too large or too small, it can be very uncomfortable. When your lens fits properly, the lens should cover the entire cornea and it should be moving slightly with each blink. If it’s moving a lot, wearers will experience dryness, irritation, itchiness, etc. If it’s moving too little, it can become irritated and red with blurry vision. Keep in mind most people should be able to wear contact lenses for up to 12 hours comfortably if it fits right.
This is pretty much the complete opposite of what ive been told everywhere.
