Yup will do that later on
ATM I am now considering returning the 290 though and going for the 780
I really like the 290 but it does run hot, (hitting 86 degrees and will only get hotter over the next few months) and I have yet to connect my second monitor so temps will increase further by about 5-10 degrees. Just having a look around and even if I get a cooler running CPU and add 2x120mm fans at the top of my case, I think the 290 will still run pretty hot.......
I just wish the 780 had 4GB VRAM and came with 3 games or was a bit cheaper.
As a result of the heat, I also think the GPU is throttling.
