** G-SYNC IS NEARLY HERE & MANY NEW MONITORS FROM AOC!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
Got confirmation from AOC that they shall be delivering G-Sync monitors to us in July and the price is much better than previously seen.
AOC G2460PG 24" Widescreen G-Sync 144Hz 1ms Gaming LED Monitor - Gunmetal @ £359.99 inc VAT
The AOC G2460PG display combines stylish design with high-performance features that will impress the most demanding gamers. From first-person shooters to high-speed racing games, you’ll never miss out on the action with 1 ms response time for blur-free images. This 24-inch display with Full HD resolution offers sharp, stunning picture quality with typical 1000:1 contrast ratios. The integrated DisplayPort connector and five USB hubs are ideal for hooking up a range of devices and peripherals, plus USB 3.0 technology offers super-speed charging and data transfer. The ergonomic stand offers hours of viewing or gaming comfort, allowing you to adjust the height, tilt and swivel, as well as pivot into portrait mode. No matter what you’re doing, smart energy-saving functions like W-LED backlighting help reduce your power consumption.
Specification:-
- NVIDIA G-Sync Technology
- Monitor Size: 24"
- Visible Screen Size: 61 cm
- Screen Format: 16:9
- Brightness: 350 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1
- Contrast Ratio Typical: 1000:1
- Pixel / Dot / Pitch: 0.276 (H) x 0.276 (V)
- Display Area: 531.36 (H) x 298.89 (V)
- Viewing Angle: 170°/160° (CR 10)
- Response Time: Up to 1 ms GtG
- Maximum Resolution: 1920 x 1080@144 Hz (DVI Port)
- Recommend Resolution: 1920 x 1080@144 Hz
- Colors: 16.7 M
- HDCP compatible: yes
- Inputs: DisplayPort
- Dimensions (WxHxD): 565.4 x 393.6 (+130) x 244.58 mm
- Warranty: 3yr
Only £359.99 inc VAT.
ORDER NOW
AOC G2460FQ 24" Widescreen 144Hz 1ms Gaming LED Monitor - Gunmetal @ £179.99 inc VAT
The AOC g2460fq display delivers non-stop action for thrill-seeking gamers. The 24-inch Full HD screen provides accurate colors, sharp images and true blacks with a typical contrast ratio of 1000:1. The quick one millisecond response time makes this monitor a real standout, eliminating ghosting and motion blur for fast-paced games and movies. Enjoy rich, full sound with the built-in headphone jack and 2 watt speakers. Integrated VGA, DVI-D, HDMI and DisplayPort connectors let you hook up multiple devices like your computer and game console at the same time. This also display comes complete with a VESA mount, giving you the option to hang it on a wall. The textured black finish and slim profile add a touch of style, whether you’re racing, role-playing or creating a virtual world.
Specification:-
- Monitor Size: 24"
- Colors: 16.7 M
- Inputs: Analogue, DVI-D, HDMI & DisplayPort
- Warranty: 3yr
Only £179.99 inc VAT.
ORDER NOW
AOC E2460SH 24" Widescreen 1ms Gaming LED Monitor - Black @ £119.99 inc VAT
The 24-inch AOC e2460Sh display was designed with speed in mind. The ultra-fast 1ms GTG response time makes it perfect for passionate gamers, as well as anyone who uses graphics, animation and film editing applications. Full HD 1920 x 1080 resolution reveals the finest details while impressive 20M:1 dynamic contrast delivers sharp imagery with deep, true blacks. The built-in 2 watt speaks offer rich, clear sound for movies, music or video calls. The stand easily tilts the screen to a comfortable position, or use the VESA mount to hang it on the wall. VGA, DVI and HDMI connectors let you hook up multiple computers, devices and peripherals. Smart energy-saving features like the W-LED backlight have earned this monitor an EPEAT Gold certification.
Specification:-
- Monitor Size: 24"
- Brightness: 250 (typ) cd/m² (typ)
- Contrast Ratio Dynamic: 20.000.000:1 (DCR)
- Response Time: 1 ms
- Maximum Resolution: 1920 x 1080@60 Hz
- Recommend Resolution: 1920 x 1080@60 Hz
- Colors: 16.7 M
- HDCP compatible: Yes
- Inputs: Analogue, DVI-D & HDMI
- Dimensions (WxHxD): 565.4 x 411.6 x 219.3 mm
- Stereo Speakers
- Warranty: 3yr
Only £119.99 inc VAT.
ORDER NOW
AOC E2470SWDA 23.6" Widescreen LED Monitor - Black @ £104.99 inc VAT
This large widescreen monitor boasts a non-glare LED-backlit TN panel with Full HD resolution. Delivering a response time of only 5 ms and a static contrast of 1000:1, the latest 70 series member comes well-equipped for both multimedia and office applications. Connect analogue signals via D-Sub and digitally via its DVI port (cables included). This energy-efficient display fulfils strict sustainability certificates such as Energy Star 6.0, TCO 6.0 and EPEAT Gold. The monitor is equipped with intelligent software to reduce energy consumption and comes in a classy, black design with texturized finish and integrated speakers. Let this stylish monitor impress you today!
Features:
- Audio out
- Eco Mode
- e-Saver
- Headphone out
- i-Menu
- screen+
- Kensington Security Lock
Specifications:
- Screen Size: 23.6"
- Screen Type: LCD
- Backlight: LED
- Aspect Ratio: 16:9
- Viewable Display Area: 531.4mm x 298.9mm
- Colours: 16.7 Million
- Pixel Pitch: 0.276mm
- Horizontal Frequency Range: 30kHz - 80kHz
- Vertical Frequency Range: 55Hz - 75Hz
- Response Time: 5ms
- Contrast Ratio: 1000:1
- Dynamic Contrast Ratio: 20,000,000:1
- Brightness: 250 cd/m²
- Max. Resolution: 1920 x 1080
- Horizontal Viewing Angle: 170°
- Vertical Viewing Angle: 160°
- Tilt Angle: -5°/15°
- VGA Port(s): 1
- DVI-D Port(s): 1
- Line In Jack(s): 1
- Audio Output(s): 1
- Headphone Jack(s): 1
- Speaker(s): Integrated
- Wall Mount: VESA 100mm x 100mm
- Energy Star: 6.0
- Warranty: 2yr
Only £104.99 inc VAT.
ORDER NOW
AOC I2769VM 27" Widescreen LED Monitor - Black @ £199.99 inc VAT
AOC 69V Series AH-IPS Monitor is equipped with the Clear Vision image performance engine and features Ultra-high Dynamic Contrast Ratio of 20,000,000:1 to enable users to see darker areas of content with greater depth. The I2769VM model is highly connectable with Mobile High Definition Link (MHL) technology thatoffers great convenience for directly connecting smartphones or other mobile devices to the beautifully crafted 27” display, to enjoy full size monitor luxury and higher quality viewing of digital content. The MHL connector also charges your smartphone while you mirror its display. The I2769VM modelhas built-in speakers, with HDMI and DisplayPort connections. The high compatibility of the monitor maximizes your multimedia experience.
Features:-
- Wide View- No changes in brightness or color from any viewing angle.
- Real Color- Consistent, uniform color at all points on the screen.
- Solid Panel- No trails, puddling or flashing from touching the screen
Specification:-
- Monitor Size: 27"
- Visible Screen Size: 68,6 cm
- Brightness: 250 cd/m² (typ)
- Contrast Ratio Typical: 1.000:1
- Viewing Angle: 178°/178° (CR=10)
- Response Time: 5 ms GtG
- Maximum Resolution: 1920x1080@60Hz
- Recommend Resolution: 1920x1080@60Hz
- Colors: 16.7 M
- Connectivity: 1x VGA, 1x Display Port Input, 2x HDMI
- Weight: 7.5 kg
- Warranty: 3 Years
Only £199.99 inc VAT.
ORDER NOW
AOC E2752VQ 27" Widescreen LED Monitor - Black **Computer Shopper Monitor of the year 2013** @ £169.99 inc VAT
The e2752Vq will be the centre of your multimedia set-up. The Full-HD model offers a large screen diagonal of 68.6 cm and a wide array of connectors. With DisplayPort, D-Sub, DVI-D and HDMI ports as well as a USB hub, connecting computers, webcams, pen drives or Blu-ray players couldn’t be simpler. The e2795Vq boasts a contrast of 1200:1 and 300 cd/m2 luminance and a response time of only 2 ms. Thanks to latest display technology, the monitor is yet easy on the environment: its energy-efficient LED backlights help saving power, while the display itself is produced entirely mercury-free.
Specifications:-
- Screen Size: 27"
- Screen Type: LCD
- Backlight: LED
- Screen Features: Full HD
- Viewable Display Area: 597.89mm x 336.31mm
- Pixel Pitch: 0.3114mm
- Horizontal Frequency Range: 30kHz - 83kHz
- Vertical Frequency Range: 50Hz - 76Hz
- Response Time: 2ms
- Brightness: 300 cd/m²
- USB Hub
- Stereo Speakers
- VGA Port(s): 1
- DVI Port(s): 1
- HDMI Port(s): 1
- DisplayPort(s): 1
- Product Width: 645.7mm
- Product Height: 452mm
- Product Length: 210mm
- Energy Star: 6.0
- Compliance: CE EPEAT Gold EuP GOST ISO 9241-307 RoHS TCO 6.0 TÜV-GS
- Warranty: 3yr
Only £169.99 inc VAT.
ORDER NOW
Oh and their stunning 4k monitor is now IN STOCK:-
AOC U2868PQU 28" 4K 60Hz 1MS Gaming Widescreen LED Monitor - Black @ £499.99 inc VAT
The U2868PQU from AOC is designed for gamers as it features a rapid 1ms response TN panel with a staggering resolution of 3840x2160. Your games will never have looked so good, but bear in mind to play the latest games at 4k resolutions you will need a minimum of 780Ti or 290X and ideally a pair running crossfire/SLI to play at 4k with maximum details with 60fps or more. This monitor is also 60Hz at 3840x2160 when connected via DisplayPort.
Featuring great connectivity with VGA, DVI, HDMI and DisplayPorts along with a full height adjust, pivot and swivel stand with VESA 100x100 support. Making the AOC U2868PQU ideal for eye-finity/surround setups. The monitors also includes stereo speakers and USB Hub as well.
Specification:-
- Size with stand (W x H x D ) : 658.9x560.6x245 (mm)
- Without stand (W x H x D ): 658.9x395.8x50 (mm)
- Display Screen Size: 28" (70.8cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 80,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 1ms (GTG)
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x HDMI, 1x DisplayPort, 1x DVI, 1x VGA, 1x USB Hub
- Stand: Height adjust, pivot & Swivel
- USB Hub: Yes
- Speakers: Yes
- Warranty: 3yr
Only £499.99 inc VAT.
ORDER NOW
AOC are making some truly fantastic kit at the moment, really looking forward to the G-Sync model for sure! :)
Good stuff, any news on when you might be getting the ROG Swift monitor in? :)
Had a meeting with Asus yesterday, the price will be crazy and the stock none existent to begin with, we will put live for pre-orders soon. Be quick as the entire UK first shipment is expected to be no more than 20 units. :(
20 units? For the whole UK? Not 20 shipments, 20 containers, 20 pallets, 20 boxes... But 20 screens? :eek:
Ah that sucks, oh well, cheers for info.
Might wait a couple of months then to see if price will be more reasonable and better availability.
That's a bit of a joke hey Gibbo? 20 units??
Well I guess they can only produce so many, bear in mind if the UK gets 20-30pc, Europe will be around 200-300pc as far bigger, far east and USA even more as they are bigger. So in the big scheme they have made a lot but nowhere near enough to meet demand.
Maybe the hold up is lack of G-Sync modules and not the actual monitor manufacturers themselves, but that's just a guess.
I was thinking of upgrading. I might wait awhile long then. Cheers for the reply:)
The G-Sync mark up is too much. I'm waiting on the ROG myself but it seems it may be prohibitively expensive to begin with so my 120hz Samsung will just have to do for now.
A description of G-sync on the product page would be helpful (maybe) although I am unclear how this differs from current tech:
G-SYNC
NVIDIA G-SYNC is groundbreaking new display technology that delivers the smoothest and fastest gaming experience ever. G-SYNC’s revolutionary performance is achieved by synchronizing display refresh rates to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. The result: scenes appear instantly, objects look sharper, and gameplay is super smooth, giving you a stunning visual experience and a serious competitive edge.
Isn't this the case without the g-sync too :confused: Seems like a gimmick 95% of gamers won't notice.
Isn't this already the case? :confused:
The graphics card controls the refresh rate and can dynamically change it on the fly to keep the frames being rendered as fast as they can be sent.
So currently your refresh rate will be most likely either 60Hz, 120Hz, or 144Hz depending on screen. This is always the case independent of frame rate.
Under GSync the frame rate is the refresh rate, the frames are drawn as soon as they are sent to the screen.
So basically no more tearing, no more need for vsync.
I've not seen it in action but it does seem like a very good technology on paper, sadly NVidia seem determined to screw it up with their pricing.
Its one of the first to market, of course it's going to have a mark up - if anyone thinks freesync is going to be different then they are deluded.
It will drop in price significantly once it's more widely available, like every other product.
