- 24 Mar 2014
- Inverness,
At this point it could be anything but before I start with the explanation, here are my specs.
Okay Here are my running processes at startup also.
below are some other programs I run in the background but not all the time.
So here's my Issue I seem to be having a situation, where my pc will boot up fine and be stable. then after a random amount of time, it will lock up no response from keyboard or mouse or screen, the currently displayed program will be present on screen but will be frozen. Any sounds at the time will be playing their millisecond of sound at the time of freezing.
I have tried:
Does anyone here have any ideas? I am at a loss and about to pull out what hair I have left
If you need any further info/ screenies. I will be watching this thread and will reply as soon as I can. I am also not discounting it may be a hardware issue, but since windows 7 was installed on a brand new SSD and fully updated, plus the fact that others have had no success with complete OS reinstalls I dont think its W7 itself.
- RAM: 12GB DDR3 (1x 8GB, 1x4GB)
- CPU: AMD FX-8150 Eight Core @ 3.6GHz (Factory overclocked)
- Main SSD: 128GB Crucial M550
- Secondary HDD: SeagateSSHDD 1TB (8GB SSD)
- GPU: MSI R9 270X 4GB Version
- PSU: Super Flower 1KW 80 plus platinum
- Cooler on CPU: OCUK Techlabs watercooler (cant find it in store anymore :/)
- Mobo: Gigabyto 990 XA-UD3
- CCC - Catalyst Control Centre
- Razer Synapse
- ET6
- Microsoft Security essentials
- AMD Gaming Evolved App
- MSI Afterburner
- MSI Gamin APP
I have tried:
- Windows memory Diagnostics - No Errors (2 passes)
( I cant change settings because keyboard and mouse have no power in memtest)
- I tried running prime95 to see if it was CPU - after 20 minutes I got another lockup
- While searching for a solution online I noticed a fix which involved turning off USB legacy support in BIOS, I altered this and seemed to work, but only for 3 weeks.
