To be completely honest I just assumed as I had x2 780's in the rig that the bracket wouldn't fit, I never test fitted it with them installed, I'm assuming you mean the pump bracket that covers the grommets?
There was going to be updates to this build, I'm going to add some lighting to the case, I'm thinking of red and white lights! I was going. to get a red led strip to light up the phanteks logo in the little window, and use x2 30cm lighting strips to light up the motherboard and GPU's!
Thanks for checking out the final build pictures though!
i'm thinking white, but i think red will also look good??
