Any recommendations on a router? Will be working with 18-22mm MDF, shouldn't need anything too heavy duty (or expensive) but want to avoid anything too cheap that will fall apart after a small amount of use.
Hmm the main thing is bit size - 1/4 inch or 1/2 inch. The 1/2 inch bits are usually for deeper working and for heavier use. The cost difference between 1/4 and 1/2 is quite high.
I was persuaded to get a drill and a good set of chisels instead. Works well but takes longer.. but 300-400 quid for a good depth 1/2" router makes me think I'll take the time instead
