Project: Phoenix Prime
So after 5-6 years out the game, and using the same system I finally decided enough was enough and it was time to get with the times. I'd like to mention a massive shout out to a few people who really helped me and continue to be a source of inspiration for this build.
LtMatt - for all his AMD wisdom and just having a cool name.
Pgreenwo - for all his water cooling help and letting me pester him on email with endless questions. Your help in educating me means phase two will be a reality as your words about buying the right parts for aesthetics was bang on.
Stulid - i posted a lot of threads and im sure on many occasions your suggestions improved my direction in parts
There are many more people that have helped massively and if I've forgotten you, please let me know and you'll get a mention!
I'm a massive gamer and I love computers, I've just never had the money to upgrade very often. I decided to go all out on this one though.
My build is split into two phases - the first being getting all my desired components and building (on air) and phase two will be putting everything on water. I had a real time choosing parts and deciding if I should go water from the start, but in the end I couldn't afford all the lavish fittings that I wanted and rather than settling for second best I figured I'd play the long game.
A little note on my choosen spec. I decided to give the noctua industrial fans a go for many reasons, but one being that the 750d has an awkward front panel that obstructs airflow and I wanted to see if the high pressure, insanely overpowered notucas would keep my sexy 290s cool as ice. It was mainly due to worries of the 290s that i invested.
My initial component list looks like this:
YOUR BASKET
2 x Sapphire Radeon R9 290 Vapor-X OC 4096MB GDDR5 PCI-Express Graphics Card (11227-04-40G) £339.95 (£679.90)
1 x Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £259.99
1 x Gigabyte Z97X-SOC Force Intel Z97 (Socket 1150) DDR3 ATX Motherboard **Overclockers UK Exclusive** £159.95
1 x SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - Black £129.95
1 x Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW) £124.99
1 x Corsair Dominator PLATINUM 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit with DHX Pro Connector (CMD8GX3M2A1866C9) £119.99
1 x Corsair Hydro H105 Extreme Performance Liquid CPU Cooler (CW-9060016-WW ) £89.99
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25.00
3 x Noctua NF-A14 IndustrialPPC 3000RPM PWM 140mm High Performance Fan £22.99 (£68.97)
1 x BitFenix Alchemy Cable Bundle - Orange £21.95
2 x BitFenix Alchemy Premium Modding LED Strip - Connect White 12cm £9.29 (£18.58)
Total : £1,716.95 (includes shipping : £14.75).
First two, dedicated to LtMatt:
Dam these fans get me all excited.
This coming soon:
YOUR BASKET
1 x Lamptron FC Touch Fan Controller - Black £49.99
1 x MTN Fixer Matt Varnish - 400ml £4.99
1 x MTN Primer / Undercoat - 400ml £4.99
1 x MTN 94 Spray Paint Fluorescent Orange - 400ml £4.99
Total : £74.57 (includes shipping : £8.00).
YOUR BASKET
This coming soon:
YOUR BASKET
