gpu recommendation
30 Mar 2014
uk
hi looking a recommendation for a gpu to run crysis 2 and cod 4 mordern warfare? im currently only using intel hd 4400 graphics and looking a cheap gpu to run the above games thanks
System specs, resolution and budget? :)
core i3 (1150) hd 4400
windows 7
1440 x 900 resolution currently
dell 19" lcd
4gb ddr3
asus mobo
something around 40-50 at most im a light gamer atm so dont want to be spending to much :( plus i dont have too much to spend lol
Yeah, you're looking at something around the used 5870/6950 price range or maybe you can squeeze a 7850/70 if you catch a bargain.
no problem thank you what games can i run on hd 4400? i know it runs counter strike as i play it all the time now but graphics seem very basic for it
Not sure tbh mate. I know that I could happily run Mass Effect 2 @720p on a HD3000 (2500K) if that helps. Not tried anything more than that apart from BF3 for a laugh (was a slideshow :D).
yeah i tryed running call of duty on 4400 graphics and it wasnt too nice was really slow and laggy and crysis 2 was really bad :) think its time to get a new graphics card!
does that msi gpu have the connectors for power supply as i dont have the relative 4,6,8 pin on power supply its standard psu i have
