- 14 Feb 2011
A lot of the results have disappeared out the OP.
Christ, looks like they were lost during update. i'll ask a Don if he can help.
I have emailed you humbug..
I keep a backup of all the threads I run. You only need notepad and it is easy to put the results back in. A pita but saves a headache.
I use Hotmail to do mine so I can use it on any PC.
Any luck getting this sorted Humbug? I've a few scores to post and i'm afraid you'll lose them also![]()
Cool. I'll wait till your Dual GPUs are back up before posting my scores. Give ya a bit of time![]()
@Humbug
Have you thought about moving the scoreboards to 5 or 6 consecutive posts on the end of the thread with links in the OP to where they are (similar to what I did with the Heaven 4 thread).
This makes things a lot easier for updating.
You are less likely to get the problem you have just had.
It looks neater too.
