- 25 Nov 2011
- The KOP
Well I didn't mean how you seem to have taken it.
Screw the stutter! Come on guys it's all good, I think if someone was to say Mantle makes no difference to the smoothness of play in BF4 then we could all agree that the person has either never used Mantle, or is talking out of their arse.
It does make a difference, i guess how much of a difference is down to the individual.
for me personally, it's very noticeable, switching between Mantle and DX11, but at the same time, if i was to play using DX11 for a few rounds I'm sure that I'd soon get used to it, to the point that i wouldn't even notice anymore.
Greg looking at the vid you posted, yes, that graph could be smoother, its got a lot of spikes in it, if you were to use a Mantle i have no doubt you'd feel the difference.
At the same time you're happy with it, that's all that matters, if you find it perfectly playable, awesome.
DX11 on BF4 is awesome, i was playing it fine before mantle was in place and enjoyed it.
Mantle Awesome-er, it makes a great difference, it makes the smooth gameplay on you'd get with DX11, feel even smoother.
Bring on DX12 and future improvement for Mantle, it's going to be great.
Get on another more demanding map with 64 players![]()
Maybe you can help these guys out who are finding BF4 a stuttering mess with their 290's Humbug?
http://forums.overclockers.co.uk/showthread.php?t=18605670
What's the best settings for mantle in the gfx settings of BF4? I haven't played for nearly 3 months and now the "Mantle Renderer" keeps crashing.
Windows 7
Cats 14.6 RC
AMD 7990
16g of system ram
i7 3.2 @ 4.6
Gone back to DX11 for now.
Back on DX11 too. Mantle seemed good for while then lots of lag. I'm suspecting an issue with vram. Aside from that BF4 is running pretty well. Any options I should turn down as most now default to ultra? Also getting cooked in this weather!
Turn Texture Quality to Medium.
Thanks I'll try that. I solved my 1fps issue by uninstalling Afterburner. Needs more investigation but seems to be causing it.
I take it is normal for two cards to kick out a lot of heat? It could get pretty warm with one. Card temps look okay only seen high 70s ºC. Think I just need an air con unit!
Think I may need a faster monitor though. Someone's seem to be dead some way away from where I thought I was standing or is that just BF4s fault?
The hit detection thing now seems to be server related rather then game, had it on the MLG server last Wednesday, seemed to be round and user specific however, those on fiber seem to suffer the least.
The MLG server will be going exclusively dragons teeth as of this evening, CQS/TDM/DOM. So feel free to pop on tomorrow evening so we can all shoot Greg with shotguns and RPGs![]()
Dragons Teeth = 7.23GB download.
@ 25MB/sec it wont be long now
Virgin Media's highest BB speed is 152MB but i usually hit 160MB![]()
Pff, 4-5MB here. Still at least im half way through.
