**Pre-Build testing log**
15 May 2012
Louth, lincs
Hi folks having a change round again as i'm wanting to accommodate a chiller into my loop. I was going to wait till i received all the components..... but i couldn't :D
Experiencing a few problems with the test bench, so need to contact the shop/manufacturer regarding this, problem is that where the acrylic has been drilled there are inserts to screw into but these inserts are not glued in properly so things cant be tightened fully and because of this when inserting say the gpu it pushes the inserts down causing the mobo to flex and cause a poor connection in the pci slot so this needs to be addressed asap.
The completed spec List, some of which were out of stock and coming next week, hopefully along with the chiller ;)
So once everything is here i'll strip down again and rebuild it as intended.
SPEC
Rampage black edition with mono block
4930k
16gb Trident X @2400 cas9
EVGA 780Ti classified + acetal waterblock
Superflower 1200w plat
Aqua computer Aquaero 6 PRO
1x 120 gb evo(win 8)
1x 120 gb evo(win 7)
1x 240gb evo (bits and bobs)
Dual DDC pwm pumps
Bitspower fittings and Koolance QDC's
2x Alphacool 420 x 140 x 80mm rads for 24/7 duties
1x 790w chiller for benching
Anyway once properly completed i shall endeavour to write a proper build log once i have rebuilt but heres some pics for now ;)
First pics need resizing so i'll hide 'em for now
could you resize the pictures?
even on my 2560x1080 its hgard to see it all
ah i hit spoiler, no worries
looking good so far!
I'll sort pics out guys when i do the proper final build log.
It does paul, temps are good too, defo seen a drop on cpu temps even though i am only running on 1 rad at the mo. TBH i could run 24/7 on that one rad but wheres the fun in that!! :D
EK need to make there instructions a little clearer, took a few attempts to get it right.
Its used to insulate/protect from moisture, going to be getting a chiller next week and have to protect against condensation when i take my water temp down to about 4c
Wow this is an impressive build and the parts you've used are all top spec as well. Looking forward to seeing this chiller your talking about and the results it gives once it's installed :)
Cheers, chiller won't do much on the CPU as I'm not temp limited but the gpu should do fairly well as the Ti's like to be cool, they must be kept below 40c to push big clocks and higher volts, my max is around 1400mhz with a water temp of 20c so with a 4c water I'm aiming for 1500mhz+
Looking awesome mate
Thx bud ;)
Few changes incoming, the Chillers on a hold just for the mo, and the Ti classy has gone and in its place is 2x 780 classy's, just awaiting my second block a certain company is being incredibly slow :( wanting a swift so the extra frames will come in handy. would have liked another Ti classy but funds wont allow at this present time, and just to please scotsdragon had to save enough to buy a mic!!!
Anyway pics hopefully weds/thurs, made myself a new work/gaming station tonight as i needed more space.
