You have to do all clever stuff to get 60 fps and it is quite involved. I did look into doing the same but too much hassle.
What do you have to do specifically?
Yep, sod that. Cheers.
CTE users, 30GB patch coming up.![]()
i wasn't doing much at the time!! not sure if its cos i'm older drivers?? can't be temps even though its running hot for water!! i'll try a different driver first i think.That looks good to me Nick, perhaps not the best screenshot example of the problems there.
one instance i got in a little bird and it felt like i was flying a concrete block, seem to be really sluggish and no idea why.
card is currently running at stock and cpu at 4.6ghz
Matt you had any issues with a memory leak with BF4 and Mantle?
Cheers, ill have a watch of that when I'm back on my pc, (on phone at the mo). Just saw shankly's post too. Problem is mainly on pearl market for me. Turning everything to lowest does make it a bit more playable.Furry muff. I will give it a butchers when i do my next vid. I got VirtualDub working with MP4 now though and here are the fruits of my labour. MP4 > AVI > H264 Lol. Probably should've just recorded in AVI to start with but nevermind.
Setter here's a single 290 playing Pearl Market 64 player conquest large.
2700k@5ghz
16GB DDR3 2133Mhz
290P 1050/1350
Win8.1 64 Bit
14.7 Beta
1080P Ultra Preset + x4 AA
Mantle API
i'm on 337.50 and yes on the new maps, not using any gpu utility
You shouldn't have to do that mate. You should be able to run full ultra with ease, though the worst explosions might see you drop below 60.
