**THE AMD DRIVERS THREAD**
Status
Not open for further replies.
I'm still using 14.6 beta. Weather aside, the temps are noticeably higher with that driver - like when watching something on youtube. Instead of idling at say 30 - 32, I'm seeing the high 40's.
Yeah when I read months of benchmarks I expected the tri x to be mid 30s max in my h440 I've got all fans on max, 3 intake 3 outtake including 2 corsairs for exhaust on rad, then a back outtake, even putting one directly onto the card as an extra didn't budge it. It tells me that there's a reading error as when it said the card was 81c under load at one point the card was only warm it wasn't even hot to touch
Crossfire doesn't work for me in Crysis 3 and I'm sure it did over a month ago.I'm using the same drivers 14.6.So I install 14.7 and it did work for short while...I opened msi afterburner and I apply OC and few options.Run Crysis 3 again,and only one card worked.Roll back all the settings ,but crossfire doesn't work .What am I doing wrong?ta
Im running 14.4. Im getting problems with videos just been a green screen, the audio can be heard. Its happens on facebook and on iplayer, however youtube seems ok. Is this a driver issue or do I need to look elsewhere? Was fine on my previous GTX670
Firstly try 14.6/14.7, if no luck:
did you do a fresh install of windows or just removed drivers and installed new ones?
I'd be thinking of doing a fresh install just to rule out drivers.
It was just an NVidia driver uninstall and then installed the AMD drivers.Ill try the new drivers and if no luck ill reinstall when I get chance :)
Sounds like a flash player issue. Which browser? Try fiddling with hardware acceleration settings, or using Chrome/IE.
Does it in IE and firefox. I thought it was flash player as well so tried a few solutions that I got off google to no avail.
I guess ill have to reinstall windows :)
Any-one have a memory leak fix for crossfire uses since the 08/07/14 bf4 patch? Other than turning off mantle or crossfire of course?
Really annoying starting out at 120FPS and dropping down to 50 after 20mins of gameplay.
Doesnt seem to fix it changing to DX??
It appears to be a pagefile problem, all starts well but after a couple of rounds system memory usage is up around 9gig and pagefile 15gig......
Not had any issues under DX. 16gb Ram install and max usage is 8GB.
Under Mantle it was using 13.7GB of Ram and brought my system to a stuttering mess.
BF4 needs Auto page file, so change that setting and everything should be ok. BF4 will use a 8-16gb page file easily.
Status
