Dual SLi Bridges
25 Mar 2013
Redditch
Just a quick question, i have seen a lot of builds that populate both SLI slots on the GPU using 2 bridges even though its a 2 card setup
Is there a benefit to this?
I have a single EVGA Pro bridge on my Titans and performance is great i was just curious
Only looks really
At 4k using a 7cm or less bridge works. Or an EVGA hard bridge. Single cables work okish but only on the left connector. Bridging the right connector at 4k causes bsod. At normal resolutions right upto 1600p it really doesnt matter hwat you stick on your cards.
It can actually be a bit worse if you have both SLI bridge slots used. I've seen multiple people say OC got unstable by adding a second bridge.
