full loop list :)
6 Jun 2014
kettering
hey this is the loop im planning on buying very soon would just like a 2nd opinion on that all parts are correct ect :) ignore the cpu ssd ect :)
also the fitting some are 16/10 and some 16/11 will that matter ?
YOUR BASKET
1 x Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £259.99
1 x Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW) £124.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £109.99
1 x EK Water Blocks EK-D5 Vario X-TOP - Plexi (incl. pump) £89.99
1 x EK Water Blocks EK-FC780 GTX Ti - Acetal+Nickel £79.99
1 x EK Water Blocks EK-Supremacy Clean CSQ - Gold £69.98
1 x Corsair Generation 2 Sleeved Cable Kit (AXi / AX / HX / TXM) - White £64.99
1 x EK Water Blocks EK-RES X3 250 Reservoir £51.98
1 x EK Water Blocks EK-CoolStream PE 360 (Triple) £49.99
1 x XSPC EX240 120mm Radiator - Black £37.99
1 x Three Fan Bundle - Corsair SP120 Quiet Edition Fan 3 pin £26.99
1 x Akasa 5.25" FC Six Channel Brushed Aluminium Fan Controller (AK-FC-08BKV2) £24.98
2 x Monsoon 16/11mm (ID 7/16 OD 5/8) Free Center Compression Fitting Six Pack - Gold £24.95 (£49.90)
1 x Corsair SP120 Performance Series High Pressure - Dual Pack (CO-9050008-WW) £22.00
1 x IcyBox USB 3.0 Docking Station for 2.5" 3.5" SATA HDD (IB-116StU3-B) £19.99
1 x Corsair Generation 2 Sleeved 24 Pin Cable (AX) - White £14.99
1 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99
4 x Monsoon 16/10mm (OD 5/8) Rotary 45° - Gold £8.69 (£34.76)
4 x Monsoon 16/10mm (OD 5/8) Rotary 90° - Gold £8.69 (£34.76)
2 x Mayhems X1 Clear Premixed Watercooling Fluid 1L £7.99 (£15.98)
1 x Arctic Silver ArctiClean Thermal Material Remover and Surface Purifier - 60ml Kit £6.98
1 x XSPC Hose Cutter (0-25mm) £6.95
3 x Primochill Primoflex Advanced Tubing 16/11 - White £5.99 (£17.97)
1 x XSPC LCD Temperature Sensor (White) V2 + G1/4" Plug Sensor £5.99
1 x XSPC PSU Bridging Connector (24 Pin) £1.99
Total : £1,255.60 (includes shipping : £13.75).
Just looking at the fittings, you should be fine as the tubing's the same as just the angled fittings specify a different size (but they should be a g1/4 thread anyway)
Any reason you're using different brand radiators in the same build? (nothing wrong with it, just curious as it's unusual)
looks ok to me. only thing I would add is a drain, they are just sooooo useful.
and tube cutters! why doesnt EVERYONE with a loop have these?
I was also thinking of changing the 240 rad to the ek one that has drain plug at the bottom and making that with a tap on it right at the bottom of the loop would it work ?
this is the final list before I head down ina few week to pick it all up :) YOUR BASKET
1 x intel core i7-4790k 4.00ghz (devil's canyon) socket lga1150 processor - retail £259.99
1 x corsair obsidian 750d full tower case - black (cc-9011035-ww) £124.99
1 x samsung 250gb ssd 840 evo sata 6gb/s basic - (mz-7te250bw) £109.99
1 x ek water blocks ek-d5 vario x-top - plexi (incl. pump) £89.99
1 x ek water blocks ek-fc780 gtx ti - acetal+nickel £79.99
1 x ek water blocks ek-supremacy clean csq - gold £69.98
1 x corsair generation 2 sleeved cable kit (axi / ax / hx / txm) - white £64.99
1 x ek-coolstream rad xtx (240) £64.99
1 x ek water blocks ek-res x3 250 reservoir £51.98
1 x ek water blocks ek-coolstream pe 360 (triple) £49.99
1 x three fan bundle - corsair sp120 quiet edition fan 3 pin £26.99
1 x akasa 5.25" fc six channel brushed aluminium fan controller (ak-fc-08bkv2) £24.98
2 x monsoon 16/11mm (id 7/16 od 5/8) free center compression fitting six pack - gold £24.95 (£49.90)
1 x corsair sp120 performance series high pressure - dual pack (co-9050008-ww) £22.00
1 x icybox usb 3.0 docking station for 2.5" 3.5" sata hdd (ib-116stu3-b) £19.99
1 x corsair generation 2 sleeved 24 pin cable (ax) - white £14.99
1 x corsair af140 quiet series low noise high airflow - single pack (co-9050009-ww) £14.99
4 x monsoon 16/10mm (od 5/8) rotary 90° - gold £8.69 (£34.76)
4 x monsoon 16/10mm (od 5/8) rotary 45° - gold £8.69 (£34.76)
2 x mayhems x1 clear premixed watercooling fluid 1l £7.99 (£15.98)
1 x arctic silver arcticlean thermal material remover and surface purifier - 60ml kit £6.98
1 x xspc hose cutter (0-25mm) £6.95
1 x xspc lcd temperature sensor (white) v2 + g1/4" plug sensor £5.99
1 x aqua computer ball valve female thread g 1/4 without fittings £5.99
3 x primochill primoflex advanced tubing 16/11 - white £5.99 (£17.97)
1 x bitspower premium g1/4" high flow 7/16"" fitting - shiny silver £3.98
1 x xspc psu bridging connector (24 pin) £1.99
1 x xspc g1/4" 10mm male to male fitting (chrome) £1.79
total : £1,294.36 (includes shipping : £13.75).
also this is my planned loop run
the loop looks good but I cant see how the drain will fit in the tight space in the front like that. on my 900D I had no choice but to put it through the sn2 PSU blacking plate at the back.
I was thinking I would fit behind the front of the 750d as there isn't going to be a fan there etc. just remove the front and you'll be able to see it if that makes sense bud ?
ok yup.
being that i dont 100% trust these valves I also fitted a stop plug to the other side of the valve. just in case! a mate of mine who's plumber mentioned that "olive valves" which is what these are quite often leak over time so I thought hmmmmm for the sake of a quid.
