So, Before I had just a loop for the cpu and now I've gone full loop the GPU will normally sit at 46c under load where is the CPU went from 22 idle to 40 idle?? Why the huge jump in temps, I have two twin rads and ones a duel thickness.
Shouldn't the temp lower more rather than jump higher? The cpu wont even run prime without touching 90c! Which I then stop because screw going higher
