Just looking for some advice from our fellow OcUK sparkies and/or DIY pr0s.
We currently have a single 2.3KW oven plugged in with a standard plug and 13A fuse and no local isolation
rolleyes
. We also have a 6KW hob on top which is hardwired in to a junction box of some kind behind the oven with a 6.0mm cable which does have a local isolation switch.
Now, we're wanting to get a new oven which is 3.4KW (so I obviously can't use a standard plug) and a new hob. The new hob should not be an issue, as there is already a nice 6.0mm connection/junction box for it. However, it will be a bit of an issue with the oven.
Now my amateur electrician mind is saying, if I get a sparky in, would they be able to somehow make the junction box feeding the hob, have two cables coming out of it so one will be able to feed the oven also? The local isolation switch would then obviously control both the oven and hob instead of just the hob. For info, the hob is on a dedicated "Cooker" circuit at the main fuse box, whereas the oven is part of the "Kitchen Sockets" circuit.
rolleyes
. We also have a 6KW hob on top which is hardwired in to a junction box of some kind behind the oven with a 6.0mm cable which does have a local isolation switch.Now, we're wanting to get a new oven which is 3.4KW (so I obviously can't use a standard plug) and a new hob. The new hob should not be an issue, as there is already a nice 6.0mm connection/junction box for it. However, it will be a bit of an issue with the oven.
If so never seen that before :-/
