Issues with Card
23 Jan 2013
Hi All
A little annoyed I am having to post this but I need a little help trouble shooting my computer. I am 99% sure its my card/drivers for card that is the issue but wanted a second opinion.
Scenario:
I reinstall Windows 8.1
All drivers for my motherboard install fine and no issues after rebooting for each driver
Install 14.4 AMD drivers and it seems fine but on reboot grey/black screen
Reinstall everything again.
Try 13.12 AMD drivers and again seems fine but again on reboot grey/black screen.
Is this likely a card issue or could it be something else? The fact that the issue presents only once the drivers are installed suggests card however I have no issue with display coming from the card until that point which is why I need the second opinion.
Cheers
Korg
are you using display driver uninstaller (ddu) to uninstall old amd drivers and do clean new install?
might help
latest mb bios? tried other bios position on the gpu?
im just thinking of things you can try,i know it was working ok before but you know what pc's can be like
ive seen a few issue's with that model of gpu tho on here
