*** Nokia Lumia 930 ***
It works. I was having issues finding the "sweet spot" with the round one, seems to have to be dead centre with the Nokia Logo on the back. Any movement and it would spot charging. This other one is more like the older DT-900 (http://www.nokia.com/gb-en/accessories/accessory/dt-900/), just dump it on and it goes.
cool I find you can just dump it on the round one as long as its below the power button. could yours be faulty/ or low powered?
It works. I was having issues finding the "sweet spot" with the round one, seems to have to be dead centre with the Nokia Logo on the back. Any movement and it would stop charging.
I've been having the same issues, very hard finding a spot where it continues charging all night.
I've had a text saying something is being delivered the 28th and the one from CW is being delivered the 28th, don't know if they will be the same one or one from the Lumia site and one from CW. Have to wait and see.
Guys if I put my phone on a solid grey screen (background) I can see faint horizontal shadows is this normal for oled ?
I went into the ee shop today to say it was faulty and they tested another 2 sealed phones and they were the same.
They wouldn't offer me a refund or an exchange saying it was fine as they are all like that.
What should I do?
I thought it was my computer USB port not giving it enough power at first, but I tried it with the mains plug too. Could be faulty I suppose, I'll maybe give Nokia a ring but don't want to return the whole lot for the sake of the charger!
Luckily I've got one of those DT-900 ones too which I got for free when I bought the Lumia 925 so I've been using that one as well.
Im having the same problems as Martin and in fact missed a nights charge because it was just off centre.
Im going back to my old pad.
Also, heres a big thing, I just got my free bundle Kit. The external portable Charge pad wouldn't charge wirelessly on the newer black cirle one, hooked up my old pad, set it on and its will charge it.
Also, with the speaker, its a good job, but I couldn't get the "Tap to connect" to work at all, had to manually sync the Blutooth to it, am I missing something, everything was switched on.
Also, as i have my phone s set to the US region so I could get Cortana, I can't use my voucher.
that's interesting with the charger, I am running mine via a powered usb splitter/ charger seems to work fine, but perhaps I am just being careful to check the light comes on
What should I do?
Nobody elses 930 do this ?????
