Spec Help - Red/Black Build
29 Dec 2013
London
Looking to finally choose some parts and do my first PC build, any speccers kind enough to help out? :)
Budget £2,000 including everything except keyboard/mouse/speakers, if possible include:
-1440p Monitor
-Red/Black colour scheme
-Windows OS
-NZXT 440 Case
-External DVD Drive
-Motherboard with decent onboard sound
- & Everything else :p
The PC will most likely be on 24/7 so coolness/quietness is a main priority, Gaming wise it'll be 1440p on mostly games like Skyrim, Civ 5, CoD and Bioshock,
It'll be my first PC build so if any components are easier to install and/or more reliable it would be appreciated, I won't be overclocking the CPU (at least not in the near future)
If there are good deals on this week I'm happy to buy half the components now and then wait till next week to finish off the purchases :)
I would go with something like this, got a bigger PSU so you can get a 2nd card in the future if you need, and bling'd it up a bit.
YOUR BASKET
1 x Gigabyte GeForce GTX 780Ti WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card (GV-N78TOC-3GD) £499.99
1 x Asus PB278Q 27" Professional LED Multimedia Monitor - Black £479.99
1 x Asus Maximus VII Ranger - Devils Canyon Core i7 4790K CPU & Motherboard Bundle **£34 Saving** £375.94
1 x EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply £99.95
1 x NZXT H440 Mid Tower Case - Black £94.99
1 x Intel 335 Series 20nm 240GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail (SSDSC2CT240A4K5) £79.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
1 x Kingston HyperX 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Kit - Black/Red (HX24C11BRK2/8-OC) £67.99
1 x Antec Kúhler H2O 1220 Series 4 High Performance Liquid CPU Cooler £60.00
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £41.98
1 x Samsung SE-S208DB/TSBS External Slimline 8x DVD-RW (TV Connect) - Black £21.98
1 x NZXT CB-LED20-RD 24x Red LED Sleeve - 2m £13.99
2 x Corsair SP120 Quiet Series High Pressure Low Noise - Single Pack (CO-9050005-WW) £11.99 (£23.98)
1 x BitFenix Alchemy 24Pin ATX Extension 30cm - sleeved black/red/black £7.49
1 x BitFenix Alchemy 6pin PCIe Extension 45cm - sleeved black/red/black £5.99
1 x BitFenix Alchemy 8pin PCIe Extension 45cm - sleeved black/red/black £5.95
1 x BitFenix Alchemy 8Pin EPS12V Extension 45cm - sleeved black/red/black £4.99
Total : £1,986.82 (includes shipping : £22.20).
Cheers for the specs so far guys, couple of questions
Heard the Gigabyte 780ti is a pretty hefty GPU, will it fit in the case without restricting too much airflow?
Also @Lee I'm not sure how well 2x290s would do in terms of temperature, do you know anyone who has a similar set up?
Hadn't really heard much about the Antec cooler you all used either, is it on par/better than the H100i?
Strongly considering the below from OCUK:
YOUR BASKET
1 x EPIC POWER BUNDLE: Intel 4790K, Gigabyte Z97X-Gaming 7, Kingston 16GB 2400MHz Kit, Superflower 1000W Platinum PSU & FREE STUFF!! **£50 SAVING** £631.92
1 x Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card £269.99
Total : £1,095.38 (includes shipping : £13.75).
Can pick up a SSD much cheaper elsewhere + can get the student discount on Win8.1 from source
Anyone reccomend a specific 3TB+ Internal Hard Drive? 1TB will get used up pretty quick so may aswell have the extra head room
As for the monitor I'll stick to 1080p for now, may aswell wait until freesync (no idea on time frames) or the price of 1440p to drop a little further
If anyone has any input or changes/reccomendations just chip in! :)
Edit: oh, could someone reccomend some good fans for either the case or cooler if they make much difference to noise/temps? If the default ones are already good that's fine too
YOUR BASKET
looks like a great build! ^ but id get a kraken/corsair water cooler personally as im unfamiliar with antec's offerings
Ended up buying this lot + a 4tb seagate mech drive, 250gb samsung evo SSD and some speakers. Should be a pretty good starting point and can always add another 290 or upgrade the GPU in a couple of years, hopefully everything else will still be going strong :)
Will try and take some photos to update this next week if the build goes to plan (or end up asking many more questions if it doesn't :p)
Thanks for the help Stulid, Lee, Fallen & Ted!
