I'm very very close to buying this monitor but need some input from those who are using it.
YOUR BASKET
1 x LG Flatron 29UM65-P 29" WideScreen Super-Wide LED Monitor £269.99
Total : £269.99 (includes shipping : ).
I'll be using this for mainly gaming & photography with the occasional film.
Have you noticed any ghosting when gaming?
Back light bleed?
What's the colour reproduction like?
Issues with HDMI/DVI/DP?
I just need to make sure this will be 100% before I pull the plug, very excited if its as good as it looks
LG Flatron 29UM65-P 29" WideScreen Super-Wide LED Monitor Owners
1. Nexus18
2. Snips86x RMA'd and EOL
3. KiiYzOo
4. Robbsy
5. Kanifee
6. hardkore
7. uksoldierboy
8. RobertoGD
Settings
Here are some settings used by the monitor owners:
10-20% brightness is ideal (if necessary, you can go higher but I wouldn't recommend it, most definitely not higher than 50% anyway!)
Either use the cinema preset, if you find the image a bit too dark overall, you can increase the gamma via nvidia or AMD's control panel.
OR
Use custom preset with these settings:
contrast - 65
gamma - gamma 1
custom RGB values - R/50 G/50 B/51
However, every panel is different so what might work best for one might not work best for someone else.
Best site for manually calibrating:
http://www.lagom.nl/lcd-test/
Good calibration test images:
http://www.smugmug.com/img/help/cali...int-1400-2.jpg
http://webtransformer.com/calibrate/...o-ICC-Full.jpg
As for response time setting, either high or medium is best. With high setting I can see inverse ghosting so have just stuck with the default "medium" setting.
This is a great site for testing the response time settings out:
http://www.testufo.com/#test=ghosting
http://www.testufo.com/#test=photo&p...uit=0&height=0
Reviews
http://en.gecid.com/disply/LG_UltraWide_29UM65-P_monitor_review_and_testing/
YOUR BASKET
Back light bleed?
1. Nexus18
2.
3. KiiYzOo
4. Robbsy
5. Kanifee
6. hardkore
7. uksoldierboy
8. RobertoGD
Settings
OR
contrast - 65
gamma - gamma 1
Reviews
