- 14 Feb 2011
Why have you run such low clocks on the Titans?
His boost clocks will be much higher. I think Kaap always puts up his none boost clocks.
I was, the actual boost clocks would have been somewhere around 1150mhz+
NVidia have had the advantage at low resolutions because the AMD drivers are really bad at bottlenecking the cards on fps, this all changes at high resolutions where you are not going to get near 180fps+ where the problem exists.
Still undecided on the 4K monitor. But if I do go 4k i'll run the bench at 1220 Core with the Titans and see how they compare.
I doubt you'll see more than 1-2fps difference.
Why?
1150-1220 does not seem like much of a jump.
70 on the cores a good jump. What you smoking?
My scores in all the benches at 4K were just place holders. I will be back on the 5Th Sep![]()
What happens on 5th Sept, have I missed something.
He's picking his 4 gtx 880's up along with his new monitor
TBH i think it's probably just when hes getting his monitor but i could be wrong
I will be picking up the Acer 4K G-Sync monitor. Your scores will be safe for a bit, as I will be doing plenty of game testing and then giving feedback in a review for noobs by a noob![]()
I look forward to it. They do look a lot of monitor for the money.
