OnePlus One.
Is anyone having any issues with the gallery app?
If I try to share a pic or set it as background image, it errors with "failed to find image".
Checking the bug tracker for cyanogen says its fixed with the latest gallery release, but it isn't...
##EDIT##
Ha ha, it appears checking the play store 7 hours later that another update shows and it now appears to have corrected the issue!
Glad I didn't enable art then. Almost did, the camera is good it seems the software is poor and without image stabilisation.
Really want a code for one of these, getting bored of my Nexus 5 now.
added you to the list chap.
Sure Joel will add to this list. Hope you like it Joel I think you will.
yeh im sure i will. extra battery life is my main excitement.
so the next person on the list is "chanjy" he's not responded to my trust message so i will also contact the next person in the line.
if "chanjy" doesnt reply by the time we get the next invite i will move onto the next person.
the next person in the list is "andrewkp" he's got 6 posts in total and hasnt enabled his trust so i will message the next person in the list "Azza"
The forums are really annoying on one plus, even if your the 1st person to post in an invite thread out of 10 pages and the guy has 5 invites to give out, you still don't get one :(
yeah thats happened to me a number of times, i actually think they dont even have invites to give out they just want likes or something to push their forum rating up.
also the begging and sob stories make me cringe.
Finally got rid of my OPO and did well to break even.
If the company manage to work out the yellow screen issue then I won't hesitate in getting another one but with the Nexus 6 around the corner I'd be tempted to get that instead.
If the company many to work out the yellow screen issue then I won't hesitate in getting another one but with the Nexus 6 around the corner I'd be tempted to get that instead.
Is there a nexus 6?
I thought the nexus line was being replaced by android silver?
Is there a nexus 6?
Yes there's definitely going to be a Nexus 6 and if the rumours turn out to be correct it's going to be made by Motorola. The only downer being it will be 5.9"
The Android Silver programme is in jeapody as one of the leads has left and Google are pondering what to do with it so the Nexus range is here for a while yet.
Started fresh mate. 5.9" is huge this is brinking on being too big I can just use it one handed in certain occasions but it's obviously much more comfortable with two.
Looking at this thread, Devious should have an invite soon, he got his invite mid july so hopefully within the next week we can get some invites in here :)
yeah hopefully he plus a couple other might start getting some. a lot seem to have got 5 invites instead of the usual 3 aswell
Uh..Three have a new app called Three in touch to make calls and texts over WiFi which is fantastic. However it won't work because it says OPO is rooted. I did a root check and its not.
