Nice scores Kaap. Why DX11 only?
I came within an ace of blowing up my 4930k trying to run Mantle at 4K and that was only @4.0ghz.
The VRAM memory problem with Mantle causes massive instability and thrashes the living daylights out of CPUs, fortunately it is not so bad on BF4.
I did do a couple of Mantle runs in between loads of crashes and will post them later. The two card run was worse than DX11 and the three card run was a bit better. I decided to give up when my CPU and PC powered off with the 4930k @4.0ghz and using 1.4v, even this was not enough to keep things stable.
