for me GVR (record and replay) isnt working at the moment..dunno why possibly bug with latest build?
did you enable overlay?
Did some actual benchmarks with DVR on/off.No real difference in FPS.Great tool
Excellent, thanks Gregster. Plan on re-formatting the PC next week on Friday so will give this a tazz.![]()
I need to learn some video editing to do some clever stuff and will have a play with something when I am off next.Gerard, what quality setting did you use mate on the recording? There needs to be a truly transparent settings list we all agree on if people are to compare the performance hit (if it exists) or not.
I'm by no means saying your results are wrong or falsified etc, I'm just curious if you used 1080p max settings, or a lower bitrate setting that'll naturally have a far lower performance hit.
ps, recording to an SSD?
I am tempted to install the app next time I update my drivers, just to try it.
However I think it was Shanks that pointed out in one of the ShadowPlay threads (before the AMD app was out) that until it can do the split audio recording from separate sources into separate audio tracks then it won't be a lot of use to the 'pro' recorders.
Are you a 'pro recorder' though? I'm certainly not aware of any recording credentials you have GM.![]()
50MB per sec is the highest quality of GameDVR @1080P. What is the Shadowplay equivalent at 1080P?
Ah very good, its actually identical to shadowplays highest settings at the same res. Guessing it uses the same H.264 codec?
Correct James. Interesting it's identical.
Just need to get 1440P/1600P and Mantle support and i will be delighted. Until then i will stick with Mirillis Action unless I'm recording at 1080P.
