Why?
I bought my car a few months ago, 2008 A3 1.8t FSI S-Line S-Tronic Sportback, 29k miles - £9995.
There are still such cars out there on autotrader and your budget is £10k... Manual cars are £1500 cheaper.
I owned a ford focus mk1, it was terrible, bits fell off it every day.
I think you are jealous tbh. You don't give any other reason why you hate Audis so much.
But you can't buy one for £5k.
If they are only worth £5k then you would be able to buy one for £5k.
Obviously, they are actually worth £10k because you don't know what you are talking about.
Worth to you is different to worth. You rightly say "worth to me" but Janesy says "worth".
Because they are better made than the equivalent Golf they are based on. I drove a mk5 before I bought this - horrid inside, compared to the 8P2 and above at least.
Audi get criticised for releasing the same car for 11 years but why change what works? Instead they facelifted it.
The depreciate slower hence they are still WORTH £10k. They might not be worth it to you but to the majority they are, otherwise there would be no point to companies like Glass.
For the average, female 20 year old, an F10 M5 is not worth £90k, this doesn't mean that an F10 M5 is too expensive does it?
neon ray bans
Ladies ladies
A3 is not happening, I quickly realised that is was a box on wheels for £10k. Currently seriously looking at Skoda Octavia Elegance, but only if I can find that model in 1.8T FSI, or maybe a VRs if I can find a good one under £9kCurse you lot, I was trying to be sensible!
http://www.autotrader.co.uk/classif..._old/onesearchad/used,nearlynew,new?logcode=p
http://www.autotrader.co.uk/classif...model/octavia/keywords/VRS/usedcars?logcode=p
