If you're on a tight budget, and never plan on getting a second card (starting with a decent card to begin with) then opting for a lower wattage PSU is perfectly fine. Computers really don't draw as much power as people think, especially when stock.
If you've got no budget constraints, then yes. 100% agree, why buy a lower tier PSU when for the few quid more you wont be limiting your options down the line. Makes sense as most PSUs nowdays come with 0db fan (low loads the unit is passive)
My posts above are not telling people to buy low wattage PSUs, thought i would clarify that. I've chosen silence and only run 1 GPU regardless of more being in my system (only tested my second 290 to proove, to myself. That the 500w is enough! Was only loaded for a 3D11 run as well, wouldn't personally risk overloading for long periods)
Agree.
I would say for a single card and gaming 500 (I'd want 600 probably) is fine.
Even in a game it won't be using all the cpu and all the gpu all the time
But if you are transcoding video you don't want your psu sitting for hours and hours above its wattage limit
But if you are doing this you will know it hopefully
To be clear mine was at its limit for very long periods of time. It wasn't the actual psu that even gave out. It was t the physical connection
Still, I got my kw psu partly due to
The warranty
The Platinum
The possibility of sitting for long periods of time in the 'optimal' power draw band
