- 21 Jul 2005
- Officially least sunny location -Ronskistats
the 7990 is a DUAL GPU card. what are you doing trying to use to argue a point against me when ive kept saying single gpu, single gpu.
The thread was going on long before your single GPU mission which I am not debating. Like I said I went from a 7990 to a 290X which is dual on one board to a single. Keep arguing over the single gpu, single gpu this thread has forked around the time you started posting.
As far as the '8 year plan' goes, do you think gpus are going to get any more power hungry then they already are between now and then? I mean, in the last 10 years ive not had a rig that pulls >500w
Not really, I could get away with a quality 500w like you mention (7990 RMA's) but seeing as they are similar in price to a larger rated one then unless your into SFF or power efficiency (*cough overclocking forum) then your continuing this on for the sake of it.
My 650w Corsair couldnt hack mining with the 7990 with additional CPU draw. Luckily it came with a 750w for that very reason.
Let's rewind back to the OP:
Here are the specs to concentrate on. The AMD rig is as follows.
AMD FX 8320 @ 4.9ghz
Asus Crosshair V Formula Z
8GB Mushkin Blackline running at 1533mhz (offsets with the FSB)
Corsair RM 750 PSU
Corsair H100
AMD Radeon 7990 ghz
OCZ Revodrive 120gb running RAID 0
Windows 8 Professional X64 (note, not 8.1 !)
Then onto the Intel rig. Note, this was a rebuild, so components stayed identical barring the board and CPU.
Intel Xeon V2 Ivybridge. 8 core, 16 thread, 2ghz
Gigabyte X79-UD3 motherboard.
8GB Mushkin Blackline running at 1600mhz XMP
Corsair RM 750 PSU
Corsair H100
AMD Radeon 7990 ghz
