Caporegime
- 9 Nov 2009
- Planet Earth
I expect the R9 280 and R9 280X will be priced more competitively than the R9 285 at launch. Its happened before with the HD6850 and HD7770 and so on.
That was posted on the previous pageDo keep up
That would be valid *if* they weren't pricing the 285 the same as the 280.
If it's going from high-end to mid-range, then two things: why is the price staying the same, and why is the number going up? It isn't the 370. If we were talking about 280 -> 370 then I'd agree. We aren't.
What we know so far is that the spec is broadly similar to the 280, with a smaller bus, for the same price.
We're talking 280 -> 285. Same series, less performance (?), same price. Hard to swallow!
While I fully agree that different silicon isn't a rebrand even if it has the same price or market placement. I just wanted to point out rebrands don't have to be perfectly identical, bumping the clocks or shrinking the die then relaunching with a new name is still rebranding.
Different clocks is rebranding, because it's the same silicon.
I don't personally consider a die shrink to be a rebrand
HD7950 > HD7950BE > R280 > R285
HD7970 > HD7970GE > R280X > R285X
If true then it's closing on the record:
8800GTS 512MB > 9800GTX > 9800GTX+ > GTS250 > GTS250 Green
The W7100 is designed to be a significant step up compared to the outgoing W7000. Along with the doubling W7000’s memory from 4GB to 8GB, the Tonga GPU in W7100 inherits Hawaii’s wider geometry front-end, allowing W7100 to process 4 triangles/clock versus W7000’s 2 tris/clock. Overall compute/rendering performance should also greatly be increased due to the much larger number of stream processors (1792 vs. 1280), but without clockspeeds we can’t say for sure.
So not a rebrand then.
Its not a rebranded GPU, You missed out 8 Ace units vs 2 and 4 Triangles per clock rate vs 2 (2 on Tahiti and Pitcairn I think) those are Hawaii Specifications, not Tahiti, and by the looks of it with some power efficiency improvements even over Hawaii.
Have to say i'm with hum on this , If amd has been paying attn they will make more of a difference for the price.I'm with FUD on this one.
From AMD's perspective, the 7950 out sold the 7970 by quite a lot, the reason is they were only about 5% apart once clocked up, how often have we said to prospecting buyers "don't bother with the 7970, get the 7950 its the same card and just as fast"
Its the same with the 290 and 290/X. AMD may well be pretty sick of that and will now make them different cards, the lesser being markedly slower and less Vram.
As for Core differences....
7750: GCN 1.0, 45 Watts
7770: GCN 1.0, 73 Watts >>>>> Now R7 260
7790: GCN 1.1, 78 Watts >>>>> Now R7 260X
7850: GCN 1.0, 96 Watts >>>>> Now R7 265
7870: GCN 1.0, 115 Watts >>>>> Now R9 270/X
7950: GCN 1.0, 144 Watts """"""""""""""""""""""""
7950 B: GCN 1.0, 184 Watts >>>>> Now R9 280
7970: GCN 1.0, 188 Watts """"""""""""""""""""""""
7970 GE: GCN 1.0, 238 Watts >>>>> Now R9 280X
R9 290: GCN 1.2, 245 Watts
R9 290X: GCN 1.2, 271 Watts
# GCN 1.0 vs 1.1:
10% performance per Watt improvement.
# GCN 1.0 vs 1.2:
25% performance per Watt improvement, 25% smaller Die per SP count, 4x more Ace units.
Speculation...
285: GCN 1.3, 140 Watts = 10% performance per Watt improvement over GCN 1.2
285X GCN 1.3 160 Watts = ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
They will always sell more cheaper products in general, Nvidia is the same. The difference between a 290/290x or a 7970/7950 isn't relevant but the price difference is.
Don't forget these are salvaged parts, the general point is getting good money for parts that can't be sold as full parts is great. You will also, depending on the product, the process, the time in the life of a process, you will have more salvaged parts than full parts available.
The 780ti came out a ridiculous time after the GK110 was in production because Nvidia were getting next to no full yield parts off the wafer. In general, particularly early on a process like the 7970/50 were, the yields are lower so there are significantly more 7950's coming off a wafer than full 7970's. They don't lose sales via 7950's they gain them. Humbug is looking at it entirely the wrong way around.
If you suggest maybe off an early wafer of 7970's you are getting 60 7950's off a wafer and 15 7970's, the 7950 is going to be sold at a healthy profit and 7970 sales are gravy.
There is a reason there was basically a 280x and no 280 for ages... because that much later on the yields on the full part were significantly up. Nvidia will have sold WAY more 780's than 780ti's. AMD sold way more 5850's than 5870's, 4850's than 4870's.
AMD/Nvidia sell more £100 cards than they sell £200 cards, which sell more than £300 cards, etc, etc. Intel the same with cpu's, they sell more dual cores than quads, then more quads than hex's(in a given segment so desktop). This isn't because of performance differentiation but more £400 pc's are sold than £500 pc's, which sell more than £600 pc's.
There is no reason for this to change, and a 50% increase in bandwidth between cards will make for a poorly balanced, badly performing card.
If yields of a full part are expected to be say over 80%, the top card will be priced to moved for the performance and the lower card will be priced very close. If the full part is only expected to be say 20% of all cores on the wafer, with another 70% being the salvaged parts then you price the salvaged part as the volume part, and you price the high yield part a little higher.
That's interesting, and I would agree.
gives this post a different outlook as well seeing as the 250's were a 55nm die shrunk variant of the original 65nm 8800GTS.
Love AMD graphics cards, but isn't this the most pointless card EU? New nvidia is around the corner, AMD should be approaching 390 etc. hmmm
Agreed. Its quite a pointless card for me
)It looks like AMD’s upcoming Fiji has something fun, something that will provide some very interesting numbers. While it won’t be here for a while, SemiAccurate is looking forward to testing Fiji.
Bit early to say that guys, wait for some reviews at least![]()
One for the gossip goats. (sadly only a few lines)
AMD’s Fiji GPU not arriving soon enough
Source
http://semiaccurate.com/2014/08/14/amds-fiji-gpu-not-arriving-soon-enough/
